driveline questions
Results 1 to 12 of 12
driveline questions
    Senior Member high flyer's Avatar
    Elsinore CA / 6 Ave
    Default driveline questions
    driveline questions anyone running a coupler off pto or must u run a u joint for flex please post pics if any trying to keep motor close to old set up u joint set up pushes motor forward to far this set up is wth a jet away I guess the question is can I run coupler direct to jetaway ? no u joint
    Quote Originally Posted by high flyer View Post
    That's because the Jet-A-Way makes the motor/pump package about 4 1/2-5 inches longer. Most people who run one usually have their pumps set back.
    Dont recomend this in a Lake boat , just my Humble 02 Tom
    Colfax, Ca
    Your question kind of confusing. I have a Jet-a-way. I moved the engine 4" forward. Did not want to do a setback on the pump.
    Do you have room to move the engine forward?? Many questions!! Hull, seating, expectations, engine, performane desires and what do you want????
    The Jet-A-way is a great addition!!!
    Elsinore CA / 6 Ave
    Default driveline
    pump is already set back stringers are cut down because it had a back seat so didnt want to move motor rails forward but i may have to extend stringers to accomodate jetaway going without is not an option so any ideas would be great thanks
    The lack of fore/aft spline "slippage" creates binding and generates heat in the coupler splines , as we speak we replacing a motor (thrust) and jet (shaft and brg failure) as a result of a "solid (single ujoint) set up" I'll post up pics tommorow Tom
    B1 Racing cs19's Avatar
    flyer, i know guys who run lencos on the river, I think that is what your asking here? Its not the best choice but will work, your engine mounts need to be very accurate though or it will create alot of heat in the splines. The pump and jet-drive must be aligned correctly. Ive seen the situation your in before with the notched stringers, tough thing to deal with.
    What kind of boating are you going to be doing? Long distance or just hotrodding?
    B1Racing.net
    Elsinore CA / 6 Ave
    Default driveline
    thanks tom just wanted to check all options it looks like ill be extending the stringers a bit john ill post some pics of the placecraft when it gets further along
    Elsinore CA / 6 Ave
    Default driveline
    mostly just hot rodding but sometimes a 3 to 5 mile run do want to keep it versatile
    Do the U-joint D/L you'll be happier Tom
    Elsinore CA / 6 Ave
    Default driveline
    done going to lenthen top of stringer where cut down and move rail kit up a bit it will work out thanks for all the info everyone going with the u joint .
    Took these pics for ya yesterday as the subject was still up here on the boards , Just for the sake of discussion and as an example this is a "ill operating" single ujoint deal someone had come up with on this customers rig to replace what should have been a short (6 3/4) Rockwell DL , in this case It took out the DL, the pump shaft splines, the front bearing and likely the Crank thrust. Tom
    compared to new
