New For NJBA 2017 Race Season
Results 1 to 14 of 17
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default New For NJBA 2017 Race Season
    January 21, 2017
    Hello People
    Making some improvement to the 149 Tsunami race program. To start, the keel was up graded, to help control the flow of water.
    To handle the improved water flow, the impeller will change to one of these, Aggressor Impellers; 2A Mag Bronze or 3A Stainless Steel. Between the two, there will be the “sweet spot” I’m looking for.
    Willis
    149 BGJ 156.74 MPH @ 1000'
    okie, lake Texoma
    Quote Originally Posted by willis View Post
    January 21, 2017
    Hello People
    Willis
    Looks good Willis. Hope you do well this yr!
    H8-2-W8
    [email protected] first pass
    Senior Member Bill Oxidean's Avatar
    Right on!
    Gardena, CA
    Default Heavy Duty Jet Drive - 2017
    January 23, 2017
    Hello People
    Hass,
    I decided not to buy any of those “HIP” jet drive processed parts yet. It will not do any good until I get the loading of the jet under control, the keel has been reworked, the loader pad/loader transition updated.
    I did get a new Berkeley Bowl and made some modifications based on what damage was occurring in the bowls that were destroyed.
    MPD, Jack and I talked about the transition changes for a long time and conclude the mods I wanted are worth trying to see if the vanes hold up longer. The leading edge of the vanes in the bowl was moved until the manufacturing cuts on the gussets were abated and then reshaped, different design on the stuffer plate for direction control. Theoretical design change should create a low pressure spot and help the water transition faster.
    Willis
    Mar 2010
    Clarksville, TN
    There goes that MPH Rule
    Gardena, CA
    Default MPH Rules - Better Control
    [QUOTE=TNYoungblood;4293066]There goes that MPH Rule [/QUOTE]
    February 8, 2017
    Hello People
    Mike
    With the new control features in place and the boat having a better response time from the new features, the MPH rule will be not a problem, the ET from start to finish will have occurred before the speed kick in.
    Willis
    Gardena, CA
    Default Blown Gas 555CID
    March 10, 2017
    Hello People
    The dyno session went well. The Verbancic Brother were awesome, pulled out some good number on the hp
    Thank Bob and OJ
    Willis
    Gardena, CA
    Default NJBA 2017 - 1st Race March 2017
    March 20, 2017
    Hello People
    Just wanted to thank all the people who were instrumental in taking the 149 Tsunami into the finals against one of the quickest Un-Blown Fuel Jets, Steve Penberthy.
    The first pass was a disaster; I had the equipment too far for the new Bennett Hull, the hull performed like it was designed to, keep the boat loaded. Just a few more adjustments and we'll put more power to it.
    Jim Brock again was the best ever advisor and friend made the adjustments that took us to the final.
    Thank you to the people who made it happen:
    Jeff Bennett
    Jim Brock
    Jack McClure
    Robert Johns
    Willis
    Gardena, CA
    Default New Hull - Jeff Bennett
    April 15, 2017
    Hello People
    Just want to say that the 2017 new intake transition by Bennett is working as predicted. The hull vacuum from launch to race completion was completely negative as it should be and no indications that it lost contact of the water. The bowl was responding a lot better than before and the psi swing from low to high was less.
    The psi of the top intake sensor has never gone from zero to 70 plus as a straight line up and the bottom respectively responded to the new transition positively too.
    As you can see from the graph, there is more room to improve on the top and bot intake response to where in the track gets bumpy, everybody has the same animal to tame and we are getting close to what we need as we run the number.
    By the way, there are no smoothing filters applied to the graph
    Sorry had wrong graph
    Willis
    Gardena, CA
    Default 2.5 A cut Brass Impeller
    April 17, 2017
    Hello People
    The choice of impellers was narrowed down to a version of 2.5 A Brass that seems to be getting the job done. As you can see from the graph that the impeller is being spun at 7950rpms with a mild tune on.
    Next race I may stand on it a little, just depends on the new bowl and how it fairs to the current horse power and hardware setup.
    Willis
    Senior Member bp298's Avatar
    LHC
    willis, it kind of looks like your max setpoint for bowl pressure is set too low in QD? looks like it's table topping. you may want to see if you can raise that setting and get the actual pressures...
    Gardena, CA
    Default QD Setting Bowl
    April 18, 2017
    Hello People
    BP
    I have the setting @ 700 and -20, the max point in the graph is 524psi. I will change the setting to 1000 and Zero.
    Willis
    Senior Member Red Rocket's Avatar
    winchester, ca
    If it's only a 500 psi transducer it won't matter what the graph scale is set on. You probably should have a 1000 psi transducer in the location.
    Gardena, CA
    Default Transducer psi rating
    Quote Originally Posted by Red Rocket View Post
    April 19, 2017
    Hello People
    Mike
    Thanks.
    I will pickup one today
    Willis
