i need sugestions for carbs on my 496
Results 1 to 14 of 29
    Senior Member OUTLAW HALLETT's Avatar
    SHASTA LAKE CA.
    Default i need sugestions for carbs on my 496
    i built a 496 this year , somewhere around 13-1 comp. with a 308/314-620 roller cam, dart heads. and a tunnel with two holley 4150 650s, ive been told by lots of people that i need more carb, i would like to know what everyone else is running, and what you think i should have on top. should i go 750s or 850s, thanks for any input, i need it
    Senior Member Futs's Avatar
    Orange CA, Big River
    850's should work just fine. My brother ran 2 650's on his 496 and it made 710 @ 6100. Think he was under carbed but it still hit the number and ran like a raped ape.
    New here Beer:30's Avatar
    Bakersfield, CA
    So, would a single 1050 dominator still be under? Seems like that would be a nice single-carb for it. Two 650s at 1300 total should be nice and crisp in the mid-range and still produce big on top end? Just a thought/question. I have not ran any big-inch carbed motors. More curiosity than anything.
    SHASTA LAKE CA.
    "they" say that eventhough when you add up the cfms, it works totally different than , a regular intake,, the motor is crisp, but it feels like it just runs out of gas on the top end, i have good pressure, i just sems like it has alot more , it just needs more fuel,
    6th Street Mafia PrecisionTile's Avatar
    Corona, CA
    Would you be interested in selling those 650s I am looking to step up from 550s.
    Quote Originally Posted by OUTLAW HALLETT View Post
    RPM range ? What is your target max rpm ?
    S CP
    cfm
    cfm is offline
    With .620" lift, is this a hydraulic roller cam ?
    What rpm's are you referring to when you say " feels like it runs out of gas on the top end" ?
    Reason why digging into this is possible valvetrain 'fuss'. Meaning, not operating in control. Lifter and/or spring related. What are your as set up spring psi's - closed, open ? What lifters ? Are your retainers steel or Ti ? What oil ? What pan ? Do you fill pan all the way full or ? What is your rocker ratio ?
    BTW: Bigger carbs can help make more power, but trying to see if you have a tune issue (carb fuel metering, ignition, or etc) or valvetrain issue. Good way to check to see if your carbs are causing a lot of restriction to airflow is to do a vacuum check just under a carb at WOT and top rpm. The vacuum is a measurement of the restriction.
    SHASTA LAKE CA.
    S CP
    now Im hitting 6400 i wouldnt say i have a target i just want what i can get, ya know. im runnign low 80s, and just like everyone iwould like a little more, it seems to me that the 650s would be alittle small, i was just wondering if there is any one who had a similar set up , and had gone through this before
    SHASTA LAKE CA.
    Quote Originally Posted by PrecisionTile View Post
    I might , i was thinking about just buying the 750 bodies , ,, by the way does anyone know if that is a good idea or not , will just the bodies, (proform) will work for me , thanks if not i will probably have to sell them ill let you know
    SHASTA LAKE CA.
    yes its a hydrolic roller, around 6400 rpm,i dont know about the springs, or retainers, they were bought to match cam, cadtrol 20/50 9 quarts in a 10 quart pan, wix filter, 1.7 comp stainless rollers
    Lake Havasu
    I also have a 496, it has two 1050 dominators.
    SHASTA LAKE CA.
    thats kinda what i was looking for , i dont think i want or need to go that far, im sure you have more motor than i do , i would think how does it run with the 2 1050s ?
    Colfax, Ca
    I am running two 850 Holleys on my 468. It does have more cam than yours. It seems to be getting plenty of fuel.
    Lake Havasu
    Runs okay...
