drain plug leak
Results 1 to 14 of 29
drain plug leak
    old HB member. 4604me's Avatar
    oxnard ca.
    Default drain plug leak
    I have a Milodon 10 qt jet pan that leaks at the drain plug. it came with a cheese O ring, that must have split at installition. anybody have this problem. or any ideas. the plug looks like a large (1"or so) anodised plug . maybe a AN plug? I'm thinking copper gasket, any ideas. thanks steve.
    just a half turn before it breaks.
    Redding, CA
    Quote Originally Posted by 4604me View Post
    I switched that plug out on my Milidon.
    If memory serves, it is a 20AN "O-Ring" fitting.
    I never had trouble with mine though.
    I put an right angle swivel adapter for oil drain hose.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Senior Member wolfie's Avatar
    I would take the drain plug out, keep it, throw the 460 away, and put a new Chevy big block in over it!!!
    Senior Member Chris The Plumber's Avatar
    Sep 2008
    Chandler
    Default Drain plug leak
    Nylon washers work good for me, most factory cars/trucks use them, you can get them at Napa or Carquest.
    Kachina Condor Tunnel hull
    Hondo Hydro pickle fork, dominator pump.
    oxnard ca.
    Quote Originally Posted by wolfie View Post
    wow thanks for the advise,-- how old are you?
    460 the "oring" with the "huge fitting" is pretty standard on thier pan design Its does not lend itself to being tightened to tight and tend to "pooch" out the oring and thus leak Maybe give thought to boring /drilling and tapping that plug thru the center and then sealing the big plug in the pan and removing the smaller plug instead !?? personally I like the extra large plug feature Tom
    oxnard ca.
    Tom I already drilled @ tapped the plug and installed a 90 for my drain hose,I guess I pinched the Oring when i reinstalled it. maybe a quadring or coppergasket, if i can find one that big.your thought's thanks steve
    Newton Ks.
    I would simply hit a good hardware store and replace the o-ring.
    Take the old one with ya.
    H.L. Mencken
    The Right Coast/SE-PA
    I did the same thing...
    if you need a new o-ring simply take the drain plug down to a hardware store and fit it up. No need to over tighten just get your 90* fitting facing towards the rear.
    Wet
    Wet is offline
    East Hampton, CT
    No shit. How many times can someone beat that f'ing horse?
    The Earth
    Blog Entries
    24
    In any oil or gasoline application make sure you use a viton (flourocarbon) o-ring, neoprene (common at auto parts stores) will swell up when exposed to oil over time. And a decent durameter (hardness rating), 75 or higher works well. A bearing supply house is probably best source locally.
    058
    058 is offline
    Not old enough to use a computer.
    ptz
    ptz is offline
    so ca
    can you tap the pan 3/8 pipe.. and put a 3/8 pipe male to -6 or -8 male 90 deg AN..and put a an cap on it ? or run an AN hose to rear of hull by the transom drain plug ? if you leave the hose long enough it will pass out the drain hole in the hull and you can drain the oil without having to scrub out the hull out with simple green ?
    something i have wondered and wanted to try out.
    Probably a lot older than you. Just having a little fun by stirring it up at your expense.
