Plumbing problems
Results 1 to 14 of 30
Plumbing problems
    Bullhead city AZ
    Default Plumbing problems
    Ok got the Eliminator wet today , but not without some issues.
    #1. Lots o water coming out the weep holes at idle (installed a new ball /spring prior )
    #2. it takes a while to get the water to come out the dump unless you rev it to 2K then its fine for awhile and then stops
    #3.so far no water in oil.
    This has a pressure reliefe valve so i open the gate valve full , and i get the rpm's up to see if its working or not and its just a drizzle. i think it starts to dump at 25 psi which i thought was a little high? Or maybe i am
    Boat ran strong , really responsive and smooth.. Just need to get the plumbing issues worked out...
    Any idea's
    Quote Originally Posted by 2savage4you View Post
    Any idea's
    Make sure you have the NARROW end of spring against the ball
    Bullhead city AZ
    taking it back out monday, im pretty sure i did but i will double check that . Thanks
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    put a ball valve on your water line to the headers iv never had consenstant luck with bassett vailves and had even worse with the banderlog valve
    Lexington, KY
    Quote Originally Posted by 78CoLeBBF View Post
    X2!!!!!!!!!!!!!
    I just give the knob on the gate valve a couple turns, and I get a perfect steam out of my headers. And definitely check how you have the spring and ball in the Bassett valve cause it doesn't work when they're put in backwards. You'll get a constant stream out of the weep holes if they're wrong.
    HJ
    Jet boat service
    Sebastopol Cal.
    I always like to put a small ball valve in the line that feeds your Bassett Tee. You do not need alot of water to the tee. You just want steam , or a fine mist out of your headers at cruise speed. The ball valve gives you more control of the water when running on the trailer which is nice also. I also plumb a little differently than the factory set ups. I talk about this on my web site under tech talk... Jim www.performancejet.com
    Bullhead city AZ
    After sitting here trying to figure out what i did wrong i remember that the bassett T had a funky top to it and compared it to another one i have... I remember now cause i told myself this dont look right at all......
    So monday i will swap tops on the t valves and give it a go... I bet that fixes here up
    Golden Shores,AZ
    rex has a valve and bassett and there was some cheapo china one believe it or not had my best luck with the cheapo and a ball valve just my .02
    El Cajon, CA.
    Nice to hear you're on the water Steve, rock on
    Bullhead city AZ
    I have the Header control valve in my Carribean and will most likely add one to the Eliminator. Just to make it simpler
    Bullhead city AZ
    hey Rod what have you been up to
    Golden Shores,AZ
    i wouldnt use a header control valve a little sand and there locked up go get a brass one from mesa pipe and supply and be done set it were it works good take the handle off and drive the boat and finish that pos carribean
    El Cajon, CA.
    Waiting for: parts, powdercoater, a jet boat builder, seat builder, and a pedal maker guy. I played baseball with a bunch of 10 year olds the other day and not only got my asss handed to me but I got injured too. Other than those things, not much.
    El Cajon, CA.
    Ouch.
