lowest MPH to run Q/E
    okie, lake Texoma
    Default lowest MPH to run Q/E
    Whats the least mph any you guys run Q/E pass with ?
    H8-2-W8
    [email protected] first pass
    okie, lake Texoma
    Well, I'll start then. I ran a [email protected]
    Was just wondering how much under that anyone has been
    H8-2-W8
    Sep 2016
    Default Low MPH
    I know that DeClark was running in the low 100s in his jet when he ran QE. I would say around 105-108, but I also believe he was moving much quicker than that during the run at the 660 mark then slowed down on the top end (my assumption is he came off the bottle around 700-800 ft depending on tune up).
    Just thought I would chime in to help, but I don't have actual numbers or pure facts on their tune up, but that is the lowest I have seen, and I only know about it because I used to give him a hard time about having such a slow boat (obviously a joke). I don't believe that you are going to get much lower than you ran without having a higher speed somewhere earlier in the run, just by pure math, acceleration, distance, etc.,but that is my $.02.
    Senior Member bp298's Avatar
    LHC
    bobsnipper ran 6.09/115 and 5.87/119. that's with no power adders. seems like kjel and declark were usually in the 10something running low 6.0s. but you ain't gonna do that with the 50' rope...
