Fuel Valves????
Results 1 to 14 of 19
Fuel Valves????
    Arcadia CA
    Default Fuel Valves????
    I have an electronic fuel valve. Is there any reason why having one of these is better then having a manual one which can run both tanks evenly like one of these:
    Got Circus Midgets??? BIGAMIST's Avatar
    S.F.V.
    Don't know witch one is better but I have a manual valve now & like it.
    When I die I want to go nice and peaceful in my sleep like Grandpa did, not screaming like the other passengers in His car.
    Charlotte, NC.
    Thats a bad ass valve...
    Quote Originally Posted by BIGAMIST View Post
    Senior Member Rain Maker MN's Avatar
    Where did you get that valve from?
    Arcadia CA
    That looks nice...theres a whole lot of shine in that pic. Does anyone have one for sale or know where I can pick one up cheap. Mine wont need to be as nice looking at that cause Ill tuck it up in the transom
    Lexington, KY
    Quote Originally Posted by Rain Maker MN View Post
    Looks like it says Hardin Marine right on the top.
    HJ
    Cas
    Cas is offline
    Angry American Cas's Avatar
    CP Performance has the Hardin Marine-
    http://www.cpperformance.com/detail.aspx?ID=842
    and Rex has Golan and Atwoods-
    http://www.rexmar.com/page196.html
    Santa Clarita
    This is the one I run... Doesn't work any better than the others and it's a little more expensive.
    Charlotte, NC.
    Edit: I Lied.. i have one of these. Works great under 30 bucks.
    http://www.discountmarinesupplies.co...UEL_VALVE.html
    Arcadia CA
    i run one of the attwood ones. Cheap and works great. Not as flash as the hardin one above but it works.
    this one?
    Charlotte, NC.
    Looks real similar.. i gave you a link above. 26 bucks plus shipping. its not flash but under the transom who cares...
    this one?
    Santa Clarita
    That valve above will only draw fuel from one tank at a time. If' thats the case just keep the electric one you have. If you want to be able to draw from both tanks you need one of the others.
    Charlotte, NC.
    I was jsut about to post that after re-reading the first post.. Yea mine only does one or the other or locks them both off.. it works for me as i like to empty one at a time so i know i have some reserve to get back to shore.
    Arcadia CA
    just looked that one up...$200...out of control. They actually require a portion of your soul to buy one of these (3/8ths summer time, 1/4 off season). Appearently they are widdled down from a solid piece of crystal with a spoon by Indonesian elders and they are tested in the Tibetan mountains then blessed by gregorian monks.
