suck or blow?
Results 1 to 14 of 25
suck or blow?
    Douglas, MA
    Default suck or blow?
    how do you change your boat oil?
    Senior Member wolfie's Avatar
    I have a hose coming off the pan and use a drill bit pump to pump it out.
    So I guess it kind of sucks!!!!!
    Morgan Hill
    Just run it to 8500 RPM and wipe the oil from the bilge and gunwales LOL...(mine has a hose also)
    GT
    GT
    on 3 go..... Slow Burn's Avatar
    Aha - SoCal.
    We use a hand drill on the oil pump drive and a hose on the block outlet. It takes just a minute or so.
    Senior Member hydroman916's Avatar
    Sep 2008
    sacramento
    I use a shop vac, turn it on, hold it by the drain plug, unscrew plug, if it sucks the plug out of your fingers use a magnet to get it out of the bucket, I have done this many times and it does not get a drip of oil in the bilge
    get blown or get blown away
    The Man cordog009's Avatar
    East Texas
    Quote Originally Posted by hydroman916 View Post
    Good idea. I've got an el-cheapo wet/dry vac that's perfect for that.
    1984 Youngblood TX-19 SOLD
    That would be suck:
    It's a little utility pump from Sears I warm up the oil so it's 125* and it flows much better. I like Slow Burns way that sounds good.
    S CP
    Q.C./Big River
    I have a drain hose (specifically designed for this) that screws in where the drain plug goes. It stays there permanently. Warm up the motor, push the hose throught the drain hol in the transom and take out the plug in the hose. Oil runs right out using gravity.
    I use a cheapy fuel pump and the drain hose off the drain plug.
    Senior Member Futs's Avatar
    Orange CA, Big River
    Who changes oil? I just keep adding so its always new...
    I do like slow burn, but i need to pull the dizzy out and then just put the hose on the oil gally plug and let er rip. Takes about three minutes.
    Senior Member W.O.T's Avatar
    Campo Ca
    I use one of those oil suckers I ordered from Overtons. Pump it about ten times and it sucks all ten quarts straight out the dipstick tube. Works great no mess. I even started using it on my car and truck.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    bought some 12v utility pump that was ment for oil, gas, etc from ebay for like 20 bucks. Works pretty good, it has garden hose fittings on both ends so i just converted it down to a small nylon hose. I stick the nylon hose into the dip stick hole and run the pump.
    Senior Member cave's Avatar
    Mesa, AZ
    I use one of these
    Works great.
    Takin it home
    Douglas, MA
    I use one of these
    Works great.
    I was thinking of picking on of these up.
