460 Ford valve adjust - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 20 of 20
  1. #15
    Junior Member HydroHaulic's Avatar
    Jun 2016
    Sweeeeet!
    Chantilly Va.
    Default C clip
    I have never seen a solid lifter with a clip? Show me one?
    AT-992 Sealed Power. SBC.
  4. #17
    Quote Originally Posted by bville View Post
    Some solid lifters have a c clip also.
    what's the purpose in a solid ? what's it holding in place a plug ?
    Take that orange dead blow or something and push down on top of the rocker where the push rod end is,or in other words see if you can make the lifter collapse.
    that's how I would have done it
  7. #19
    Senior Member bville's Avatar
    Sep 2009
    Glasgow, KY
    I,am not sure I understand what your asking?But I will say this,it is a solid and should be treated as one.A C- clip holds it together,and if you shake it it will rattle but the center piece does not move.What this type lifter does is restrict the oil flow to the top of the motor at high RPMs.
  8. #20
    New Jersey
    A Solid Lifer that is actually solid is very heavy. In order to lighten the lifter for less valve train mass they often make the body of the lifter hollow, then they put a plate with the push rod pocket on top. The push rod socket rests on a shoulder in the lifter body and is held in place with a c-clip.
