Holley Throttle Bracket Input Needed
Results 1 to 7 of 7
    Apr 2017
    Default Holley Throttle Bracket Input Needed
    Looking to find what throttle cable bracket to get for my push style pedal / cable setup. Going from a stock BBC intake and Edelbrock carb to a Edelbrock Victor Jr. with a Holley 850. Attached are pics of the existing bracket which is clearly not tall enough once I attach the linkage to the top push mounting position, let alone with a 2" carb spacer. Looking for the best setup, so what is everyone running? Links to Summit to purchase and pics installed would be greatly appreciated.
ID:	965418   Click image for larger version.
    This is a pretty standard setup, plate has Holley pattern and goes under carb, and then but the associated bracket that works with your cable. 33C type is pretty standard.
    Carb Linkage Bar, Cable Brackets
    Apr 2017
    Thanks for the help, I ordered a few options and am going to see what works best for my application.
    Aug 2014
    I took the bracket you have cut a plate to go over it and welded it.to raise it up......
    Quote Originally Posted by Dchallenger View Post
    Certainly that can work, but the flat plate that bolts under the carb costs like $20, and makes a neat install.
    Aug 2014
    by time I got to the throttle linkage the money was gone.covered engine.works just fine........
    Apr 2017
    I ended up going with the CP bracket and cable installation kit, arrives tomorrow so I will post up a few pics once installed.
    Stainless Steel Throttle Cable Bracket For Holley & Sea Demon Carburetors - CP Performance
