Boight a 78 baja with a 455 berkley jet. Jabe heard horror stories on oil issues with
Results 1 to 6 of 6
    Junior Member ssheberer's Avatar
    Jun 2017
    Indian
    Default Boight a 78 baja with a 455 berkley jet. Jabe heard horror stories on oil issues with
    78 baja engine swap a good idea or not
    Jun 2017
    Indian
    I have a 355 sbc 504 hp. 545 524 cam.. Aluminun 202 heads.. Forged 13.5.1 pistons. Vic jr highrise. 850 bg carb. Roller rockers and cam. Would ot be a good odea to junkk 455 and replace with sbc?
    Jun 2017
    Indian
    Default Engine swap
    Original 455 or sbc. Which would make this thing cruise faster?
ID:	975833   Click image for larger version.
    Default 455 bad rap...
    There is nothing wrong with the Olds 455 as a marine engine... Thousands of them were installed during the jet boat era without any issues... The trick is to use the engine/boat combination as it was intended to be used... You are not going to set the world on fire with that boat, use it as it was intended to be used, for FUN. Changing to a SBC, or even a BBC will not make that much difference in over all performance without expensive pump modifications...
    Use it as it was intended to be used and you'll be on the water having fun while the heavy hitters are on the beach with a variety of issues associated with trying to make their boats something they're not....
    Ray
    PS DO NOT put the foam back in that airfilter unless you want to have a weenie roast as the boat burns to the water line..
    LOUD BOATS SAVE LIVES
    Apr 2012
    Good advice.
    I'm running a USCG approved KN filter that looks like a standard automotive filter. Sometimes I wonder how thats approved, but I don't make the rules haha.
    "I'd love to help you out wags, but there is larger issue concerning breast cup sizes on another thread that we have to work thru first. This subject suddenly became a non issue." - GN7
    Jun 2017
    Indian
    Thanks for the info. I dont have that filter on it now.. Took that pic when i bought the boat. Thinkin i will fix jet on it and sell it and get me a smaller faster boat though
