Calgo steering pointers
Results 1 to 10 of 10
    Feb 2015
    Default Calgo steering pointers
    The calgo steering is the last thing to do before it hits the water, I need some pointers on the installation any advice would help out alot for a smooth install,thanks
    Feb 2015
    Someone had to of installed there Calgo out there,,,
    Apr 2010
    Rocklin, Calif.
    Quote Originally Posted by leadslinger View Post
    I would call Chris at B-1 Racing or Greg at GS Marine
    Colfax, Ca
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    I have done a few
    QE 439 Twin Turbo
    Feb 2015
    Too grease or not too grease the cable when installing it into the sheath Half the people who have done these say grease the other half say not to ,,,any input before I do it this weekend would be nice,the instructions say grease but sometimes there wrong ,,,,
    Senior Member Nailhead's Avatar
    Castaic Ca.
    I always grease mine after I had one freeze up on me. The cable is stainless but inside the housing is not.
    Feb 2015
    Quote Originally Posted by Nailhead View Post
    Thanks,
    New Port Richey, FL
    Grease
    QE 439 Twin Turbo
    Feb 2015
    So I got the steering all installed and tightened the cables snug ,released the timing plug /bolt and had some play in the steering reinserted the timing plug and again tightened the cables some more, they were a tad loose ,worked the steering back and fourth numerous times and had the cables again loosen up so put the plug back in and re-tighten the cables to a snug tension like my kids calgo tension on his boat ,worked the steering again back and fourth numerous times and cables are good but it feels like cable friction in the housing and everything is generously lubed is this because its new and needs some break in time, The cables are not over tightened and I do know they will have some cable stretch in the near future,Any thoughts on this
