U joint question
Results 1 to 7 of 7
U joint question
    Aug 2012
    Default U joint question
    Last trip out as I was getting up on plane, I hear some constant loud knocking coming from the rear of the boat, sounded like engine was letting go. Good oil pressure and temperature. Removed valve covers, cut oil filter, nothing...clean, plugs good as well. Still not saying I don't have an engine going south but thought I'd take a look at the drive line before pulling it.
    My question is; how many bolts connect the u joint to the flexplate? There are three in a triangle pattern but I'm seeing a 4th hole with nothing in it. Wondering if that empty hole is for a universal set up or have I sheared a bolt?
    Another question, if in fact this noise is coming from the u joint, would grease alone correct that? I have also greased the zerk at the pump/yoke.
    No trash in the pump looking down the inspection hole however, I haven't had time to remove the grate to check for shaft play....that's job next.
    Feb 2015
    Crank dowel pin hole,,,,
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    Lake Havasu az.
    U-joint companion flange has 4 bolts that attach it to adapter that bolts to the crank..if it only has 3, that is a problem. Bad u-joint will be loose in the caps or have tight spots as it is rotated.
    Apr 2010
    Rocklin, Calif.
    Look for cracked or broke flex-plate also
    Aug 2012
    Many thanks for the replies, flash light and mirror confirmed crank dowel pin hole. Drive line is fine, engine is terminal. Back to square one.....
    Feb 2015
    Quote Originally Posted by 1320 View Post
    What do I get,12 pack of IPA
    Aug 2012
    Quote Originally Posted by leadslinger View Post
    Hell yes!
