Oil on the transom?
Results 1 to 14 of 24
Oil on the transom?
    Bakersfield
    Question Oil on the transom?
    Everytime I run the boat I end up with oil on my transom, gas tanks, battery, you get the idea. It's a 468 BBC, Melling HV pump, finned aluminum valve covers with moroso baffles on the underside, K&N push in breathers. I also have a set of bolt on aluminum stack type breathers I haven't installed yet, my question is;
    Do you guys think the additional breathers will cure my problem?
    What about a puke tank?
    What about evac tubes off the headers? Will evacs work with slip in baffles?
    Other than the oily mess after each session, the boat runs perfect, anyone got any other ideas?
    Skip
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    mite be too much oil in the pan just a thought
    ptz
    ptz is offline
    so ca
    Red face
    hang some zoomies on there...
    could be the vacuum from the headers pulling earl out of the valve covers..
    monkey love
    "why is my stuff shit... and your shit stuff ?"
    "If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." Samuel Adams
    Skip lots comes to mind but ,maybe give some thought to a cylinder leak down test ? just to be safe , simple and easy call if we can help Tom
    Bakersfield
    Thanks guys!
    Not too much oil in the pan, double, then triple checked it.
    Leakdown test was good in Feb, nothing really major to note
    Tom-
    That little puke tank setup there, do you stock those? PM me a price.
    Thanks again
    Cas
    Cas is offline
    Angry American Cas's Avatar
    If you don't have PCV valve, adding one would probably help. Tom is right about the leak down test as that will tell you a lot.
    how much run time is on the engine?
    ptz
    ptz is offline
    so ca
    is it set up with a pcv valve ?
    monkey love
    PM sent Tom
    Bakersfield
    No PCV as I have no vacuum port to run it to, manifold has no vac port, carb spacer has no port, carb is an HP model, again no vac port. The dipstick loss is almost negligible, it's not a bunch of oil, just a bunch of mess.
    ptz
    ptz is offline
    so ca
    Red face
    you need a pcv valve .
    drill and tap the carb spacer 1/4 pipe and hang a fitting on there and put a pcv valve on the valve cover.
    pcv will pick up some free hp.
    the condensation is puking out from crankcase pressure.
    we had an old flat with a sbc.. the rear passengers used to get a hot oil treatment..worked almost as good of coppertone..LOL.
    in the early days cars had road draft tubes .. the air moving under the vehicle would draft the crankcase vapors out from the engine.. diesels used them up until a few years ago...
    then postive crankcase ventilation was discovered..
    could also use a smog pump as a vacuum pump...
    monkey love
    [QUOTE=ptz;635777]you need a pcv valve .
    QUOTE]
    I was thinking the same thing but is it really worth HP ?
    S CP
    Bakersfield
    I'd rather not drill the spacer, I paid a lot of damn money for it and I don't particularly want to f*&k it up. So if a PCV valve would do me right, would a set of evac tubes do me better?
    Douglas, MA
    [quote=Sleeper CP;635780]
    Quote Originally Posted by ptz View Post
    QUOTE]
    S CP
    I have had this same issue...I don't think you can run a PCV with turbos
    Quote Originally Posted by Luckie Stiff View Post
    Yeah ,but who's going to weld on the headers ? Drill and tap the spacer no big deal.
    S CP
