Oil steam?
Results 1 to 10 of 10
Oil steam?
    Denton, TX
    Default Oil steam?
    So I was reading Lucky stiff's thread and didn't want to hijack. Last time out boat ran fine minus some carb issues but I noticed steam coming out of the Breathers. Plus it had a fine mist of Oil coming out from under the valve covers. Is the Oil getting too hot? or is there too much pressure in there and the oil is just finding a way out? The oil Pressure was fine the whole time.
    Default Got milk?
    Quote Originally Posted by Btnhtillidie View Post
    Any milk in the covers??? OIL doesn't "steam".....Or is it blow by?......And how does oil "mist" come out from under the valve covers?......Ray
    LOUD BOATS SAVE LIVES
    As was stated in the other thread you may want to do a leak-down.
    I had more pressure than normal once did a leak-down everything showed fine but I knew something was not right and I remembered I had forgot to re-trq the heads after a trip to the river. Yep the normal 150 ft lbs was down to 110 ft lbs. Re-trq'd them and next trip every thing was fine. This has happened twice in 20+ yrs of boating.
    I'd try a leak-down and see what you get.
    S CP
    El Cajon, CA.
    X2
    What engine is in your boat Btnhtillidie?
    Denton, TX
    I plan on doing a leak down test this week. When I said mist I meant fine spraying of oil out form under the valve covers. Not a lot but just enough to let you know. Also no milkshake under the valve covers oil looks nice and purple (I run Royal Purple) If oil does not steam where was the steam coming from? Water temp was fine around 150* or so.
    Denton, TX
    X2
    Its a lil 327 .30 over forged internals, roller rockers, with a 144 atop of it.
    There is no sign anywhere of water in the valve covers.
    How long has it been since the boat was run before the recent trip? Could it simply be burning off condensation in the oil and engine?
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Denton, TX
    Quote Originally Posted by DMOORE View Post
    Darrell.
    ohhh thats a good one. Damn I didn't even think of that, That was it maiden voyage since Aug/OCT. First trip of this year.
    Alot depends on Alot! the steam/mist is likely due to some crancase pressure , and the little blower just aggravates the problem make sure the VCs are "baffled and put the biggest breathers on it you can ,throw on a Puke tank and call it good Call if I can help Tom
    PS have the same problem on my Family boat:
    New here Beer:30's Avatar
    Bakersfield, CA
    Yes, being supercharged you are definitely having some crankcase pressure/blow-by. There can be oil steam/smoke from breathers as the oil temp is usually a bit higher than engine temp. Especially a supercharged motor; I would not be surprised if you are in the 200* range. There will always be some steam at those temps.
    There should NOT be any oil MIST, though. If there is, there is too much pressure and it's pushing the oil out of the motor. Check the crank seals front and rear also. This much pressure usually pushes some out of them.
