Electric fuel pump
Results 1 to 8 of 8
Electric fuel pump
    May 2016
    Default Electric fuel pump
    Where are you guys mounting your electric fuel pumps?
    Jul 2016
    In the tank
    Senior Member SPECTRA-SANGER's Avatar
    Sep 2016
    Default Pump Mount
    On my flat and day Cruiser I mount the pump on the transom, in my opinion easy to feed from both tanks and helps clean things up. The flat I hidden as the rear deck over hangs a bit but the day cruiser is exposed. I repurposed a coil cover to fit over the pump
    Quote Originally Posted by MadGunner View Post
    The majority of electric fuel pumps should be mounted below the fuel tank or fuel source. Some electric fuel pumps can be located in the fuel tank, but some cannot.
    Electric can usually push fuel well, but not so good at pulling it.
    May 2016
    Ok thanks guys, much appreciated.
    Lake Havasu az.
    And if you run 2 tanks try and get the 2 lines going to the t to the pump equal in length, the level in each tank will stay almost the same.
    Apr 2012
    I have mine mounted off the stringer next to the engine, about 10" above the stringer, above the bildge area to keep water off it. But this is still about at the level of the lowest part of the fuel tank. I also have a very short hose between the suction side of the pump and the water fuel separator. All straight fittings or easy bend AN fittings that don't restrict flow. Zero issues, no flat spots or hiccups when accelerating. if you mount a "gerator" style inline pump high up, you will have potential suction and flow problems. Keep it low.
    "I'd love to help you out wags, but there is larger issue concerning breast cup sizes on another thread that we have to work thru first. This subject suddenly became a non issue." - GN7
    Apr 2012
Name:	ScreenHunter_354 Jul. 24 09.31.jpg
ID:	981625Click image for larger version.
Name:	ScreenHunter_355 Jul. 24 09.32.jpg
