intake epoxy
Results 1 to 11 of 11
intake epoxy
    Senior Member Factory502's Avatar
    Default intake epoxy
    what is the name and where can I get the epoxy used to set the intake Thanks
    We use Sea going 'poxy putty Tom
    So Cal
    Sea Going Epoxy Putty from Rex Marine of course ... Click here for the link to their site
    Ladera Ranch
    Buy the two one quart package(makes 2 quarts). On my boat the 2 one pint deal was enough, but not on my dads boat...found out the hard way.
    El Cajon, CA.
    Can Marine Tex be used to set an intake?
    So Cal
    what he said
    I find Marine tex is not up to the task, does the same job, but is brittle. Sea-Going Epoxy will give a little, as there is some flexing in the hull, helping keep your intake sealed.
    The Earth
    Blog Entries
    24
    I fully agree with you. Marine tex drys very hard.
    Also clean up with Sea Goin is with water, Marine tex...not.
    and thanks for the link Busby.
    Avondale,AZ.
    Sea-goin has a package date stamped on the side of the can. Ask what it is before purchase. Even if unopened, it has a shelf life. We don't buy any that is over 3 months old. It gets harder to mix and doesn't fill the voids as well. If your deal isn't a max effort, the harder mixing is the only issue. The older it is, the shorter shelf life it exhibits upon opening and the slower cure time under certain conditions. Your results may vary. TIMINATOR
    Thanks for the info
    bo when you goin out?
