Getting close, finally!
Results 1 to 14 of 36
    May 2014
    Default Getting close, finally!
    Rebuilding my 87 advantage. Started with just a new motor build but my dumb ass had to do everything at once.
ID:	983201   Click image for larger version.
    May 2014
    Building a 565 bbc that should hit the dyno in a couple of weeks.
    Member boat498's Avatar
    Mar 2017
    Nice, got any more pics?
    May 2014
    Yep just trying to down size them. Nice boat in your avatar.
    May 2014
    More pics
ID:	983353   Click image for larger version.
    May 2014
    Chris at b1 did my pump.
    Mar 2017
    Quote Originally Posted by f-bomber View Post
    what kind of horsepower are you expecting? We put a 540 in ours with 815hp @6600rpm, so far boat has ran a 9.79 @102 in the 1/4
    Chris did the pump also, more left in it but we were running the 10.0 class and was trying to slow down anyways
    May 2014
    Hoping to make 900+ spinning it to 7200. 9.79 is moving!! Looks like close to the same boat.
    May 2014
    Loving my clown wheel!
    May 2014
    Quote Originally Posted by boat498 View Post
    Have a pic of your boat?
    Mar 2017
    did you move the placement of the motor or the pump from stock? Chris moved my motor forward 8" and reset my pump, the pump was already set back some but was off the center line about a 1/2"
    attached is a link to another website where I have a build thread going on, need to update it as I just got the cf# and stuff painted on Tues. There's alot of pics in that thread
    1986 Advantage
    May 2014
    Badd ass build!!
    May 2014
    Going to start building my race plates. What do you guys use for thickness? I'm thinking 3/16
    Mar 2010
    Clarksville, TN
    I assume your talking about Transom plates, 1/8 is fine
