Undersize impellers
Results 1 to 8 of 8
Undersize impellers
    One part at a time... JohnnyNitrous's Avatar
    Surrey, BC, Canada
    Default Undersize impellers
    How far under can you go before the impeller needs replacing? Also, I can't get a bronze shouldered wear ring in the undersize I need, should I go with stainless shouldered or the ultimate wear ring?
    Jet boat service
    Sebastopol Cal.
    I don't like going farther than .025 Max. But people do it all the time. The S/S or ultimate will work fine. How far do you need to go? Jim
    Surrey, BC, Canada
    Mine is 0.030 under.
    Jet boat service
    Sebastopol Cal.
    I have a bunch of .030 and .040 over ultimate rings been on my parts shelf for years. If you want to use that impeller I'll give you a good deal on a .030 over. PM me.. Jim www.performancejet.com
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Check PM's man
    Quote Originally Posted by Performance Jet View Post
    once i get to .40, its time for a fresh impellor. go with the ultimate wearring love em!
    B1 Racing cs19's Avatar
    Quote Originally Posted by JohnnyNitrous View Post
    If there is a wear ring available that fits the impeller correctly you should be able to run it. Obviously the impeller will be thinner than it was at STD. at .030-.040 under but life goes on and it should not be a problem for a stainless, if its aluminum just get a new one cause its on its last leg anyways.
    It doesnt seem to bother some of these yahoos who go and cut .025 off a $1000 impeller just to make it fit in an $80 wear ring.
    Just like a crankshaft or any other parts, having them being correct size (STD.) is ideal for alot of reasons.
    B1Racing.net
    Surrey, BC, Canada
    It is a stainless "B" and is prepped by MPD so I would kinda like to use it. I mistakenly ordered a standard bronze from [email protected] without measuring it first. I sent it back and hes gonna take care of it. Thanks for the replies.
