So is this salvagable or trash???
Results 1 to 10 of 10
    Q.C./Big River
    Default So is this salvagable or trash???
    This is what I found today when I took off one of the heads. I don't even want to take the other one off. #4 and #6 had 0 compression that's what led to taking it apart to find this. The head is definately toast. There is a nice crack between 4 and 6. If it is salvagable then I will be in the market for some good aluminum heads. Chime in and let me know. Thanks.
    Morgan Hill
    It depends on how deep the gouge is. a machine shop will be able to tell you for sure, you can only deck the block so far, I am going to say it's block time
    GT
    GT
    Senior Member liquidator559's Avatar
    Clovis Ca,
    This is what I found today when I took off one of the heads. I don't even want to take the other one off. #4 and #6 had 0 compression that's what led to taking it apart to found this. The head is definately toast. There is a nice crack between 4 and 6. If it is salvagable them I will be in the market for some good aluminum heads. Chime in and let me know. Thanks.
    you should be able to have that welded and be good as new ,., i had that happen to me back in the 70s ,bad gas
    The Earth
    Blog Entries
    24
    Saw this many times on turbo engines. Should be able to weld up with no problems.
    Cracks may be another issue if they're in the cylinders. Sleeves can fix those though installed properly.
    At some point tho you have to figure if the block is worth saving in terms of $ depending on it's condition, other machine work required, etc.
    i got skiillllzzzz.... fast76rogers's Avatar
    clearlake ca
    Default dam!
    looks like you could have used the box i had
    Default Maybe
    It could be saved but the expense may be equal to another block. Repair it for a grocery getter station wagon............Is it a 4 bolt?.......I have some 2 bolt blocks if you just want to get back on the water, also some ready to run cylinder heads.......Ray
    LOUD BOATS SAVE LIVES
    Q.C./Big River
    Quote Originally Posted by fast76rogers View Post
    Haha very funny. It has been like this a long time jerk off. Rub salt in the wounds that's ok. I hope we meet at the river sometime. Well see how fast your rogers really is.
    So Cal
    so the head has a crack or the block does?
    I'd take it apart and get the block over to the machine shop. There is no way we can diagnose for you over the internet.
    Good luck.
    Redding, CA
    There it is.
    I have a couple 2 bolt blocks with cyl. cracks. Yes, they can be sleeved and the cracks repaired, but to what end?
    Boats have a way of exposing weaknesses very quickly.
    Personally, I would not put it back in a boat, or any other performance/ endurance application.
    Just my .02
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Q.C./Big River
    It is a four bolt Merlin 509. I don't think the machine work is going to cost as much as it would to replace it but I am looking for a new one just to get on the water until I can get this one put back together. What do you have and how much you asking? Thanks.
