Kodiak Riser Manifold BBf plumbing ??
Results 1 to 2 of 2
    Apr 2017
    Default Kodiak Riser Manifold BBf plumbing ??
    I purchased a 21ft Taylor Jet with a 460 Ford ....The boat has Kodiak Manifolds with stainless risers.....how do I know I the exhaust is plumbed properly?
    From the T stat housing water enters the manifolds.... There is also a port that has been blocked off on the front radiused part of the riser is this normal ??? Does anyone have any info on Kodiak manifolds or a diagram thanks!
    New Jersey
    If you post a picture showing the water hose(s) to the manifold that would help.
    Doug
