Reverse gat set up for neutral.
Results 1 to 9 of 9
    Colfax, Ca
    Default Reverse gat set up for neutral.
    Would racers be so kind to post pics of their gates set up for neutral?? Thanks
    Is this real or the "Twilight Zone"?
    Mar 2010
    Clarksville, TN
    This is all I have, you've seen my bucket
    Colfax, Ca
    Saw your bucket last year. Could use some help here peeps
    Iuka, Mississippi 38852
    My bucket is completely closed when sitting on the line. You definitely don`t want to be to the left or right of the above blue boat.
    Mar 2010
    Clarksville, TN
    I'll get you a few pics of some I have
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Henry's gate on the red boat.
Name:	Henry's Bucket.jpg
    QE 439 Twin Turbo
    Senior Member bp298's Avatar
    LHC
    don't have any pics of my original. I carved up a half inch piece of aluminum so it would fit snug and flush in the reverse chute. drilled small holes through the chute and into the aluminum block, tapped the block for 1/8" screws. then drilled 3/4" holes in each side of the chute. worked great for 9 years. now slightly modified, but same concept. block the reverse, provide a flow path out each side when bucket is closed. if the boat won't sit still, figure out what it's doing and fine tune.
    Member boat498's Avatar
    Mar 2017
    here are some pics of what we use, we still use the boat to cruise around the river so we take this piece out and still use the stock reverse bucket
    granted, this is not an all out race boat but it does run the10.0 class njba and 8.0 1000' modified eliminator lucas oil ADBA
ID:	987906   Click image for larger version.
ID:	987882   Click image for larger version.
ID:	987890   Click image for larger version.
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Race Bucket
    September 2, 2017
    Hello People
    The race bucket is from Place Diverter and the mods were done by me. On installation the boat would back up with the diverter in launch position.
    The holes in the bucket were added to stop the backward motion, it works fine for my application.
    Willis
Name:	Neutral Bucket.jpg
    149 BGJ 156.74 MPH @ 1000'
