berkley jet question
Results 1 to 9 of 9
    valley springs, ca
    Default berkley jet question
    i have a spectra 20 with a 12jc and a place diverter. attached to a 460 ford. can i put a droop snoop on the pump and will it help the hull. i see the 12jc bowl may need to be changed to accept this. any ideas. it has a loader and unknown impeller
    Lexington, KY
    Quote Originally Posted by sangerfan76 View Post
    You need to get a JG bowl or some other type of split bowl to run the droop or any other type of bolt on hardware. No idea on whether or not it will help the hull though. Good luck.
    HJ
    Based on that particular hull design, weight and size I don't belive you would find a droop of great advantage, If you were to consider this you would need to swap out the bowl for a "split bowl" (12 j G,B,A, or Turbine, Dom, Agg... Tom
    Morgan Hill
    X2, That boat is built like a battleship and is pretty heavy, I think a droop will just raise the speed at which it will fall off of plane and have too much bowlift during take off...
    What are you trying to achieve?
    GT
    GT
    valley springs, ca
    its a cruiser and thats all. im just trying to make it as efficient as it can be with a fairly stock 460. bolts out of the hole and runs ok but i think i could loose some low end to put on top end
    Morgan Hill
    The trick IMHO to getting a cruiser to work well is to move as much water as you can and weight distribution.
    If those are right, it should be close to a 60 MPH boat, if you want more than that it takes way more horsepower, which in turn takes more money, which breaks more stuff, costing more...well you get the picture I'm sure
    Does yours have a set of trim planes? Our Spectra 20 responded very well with a set of 12" Bennets. (1979 Spectra 20, 455 Olds, Place and a 12 JCAA with a non blocking loader).
    GT
    GT
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Went from this to this...
    Was on Lake Berryessa last Sat. boat did 62.6 on GPS @ 5,000 RPM.
Name:	Our boat at Lake Berryessa 005.jpg
ID:	39829   Click image for larger version.
Name:	'08 boat pictures 002.jpg
ID:	39830   Click image for larger version.
Name:	'08 boat pictures 003.jpg
    Loose, the Dogs of War!
    valley springs, ca
    well engine is new but carb was all messed up. i just bought a new 750 for it. i noticed the ignition is a ford dist with a box and probly could use upgrade. all fuel lines are being changed and got new fuel pump. it has a bone stock on it. boat would only turn 4k on the rpm and was quite sloww if felt like it had more but wasnt there. engine is out and going in this week
    valley springs, ca
    i may saw 45 with it
