Fuel filter and/or separator before or after pumpkin?
    Senior Member az_mike's Avatar
    Apr 2009
    Phoenix
    Default Fuel filter and/or separator before or after pump
    Starting to think about plumbing on my daycruiser build... BBC/Holley carb, mech fuel pump..
    ive read conflicting stuff about fuel filters and where to put them.
    1. Is a filter/water separator a good idea (like the Wix 33405 or FST remote screw on) or a waste ?
    2. Read one place that AFTER the pump (under pressure) can start a fire if a leak, but BEFORE a pump can cause vapor lock?
    3. some guys I understand run two.
    What are people running in their lake boats?
    what is ideal?
    Phx
    Default filter filter
    I've always run the filter/H20 separator before the mechanical pump (holley 110). One hallett was -8 lines from tanks to the filter and -8 to the pump (496 with single 950 holley). Current hallett is -10 from both tanks to the separator and a -10 to the mechanical pump and -8 to the carb(565 with single 1150 dominator)
    Senior Member TexasJet's Avatar
    College Station, Texas
    Before fuel pump in both boats. No issues.
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Helful tools
    September 4, 2017
    Hello People
    You may find this article helpful.
    https://www.jegs.com/InstallationIns...510-12-150.pdf
    Willis
    149 BGJ 156.74 MPH @ 1000'
