Low/no water pressure. Overheating
Results 1 to 14 of 17
    Jul 2016
    Default Low/no water pressure. Overheating
    Kinda stumped. Jet boat is overheating. Not getting alot of water pressure if any out of pump to engine. Pulled lines. Flushed everything out. Looked into pump housing outlet and it looks clean. Intake area looks clean as well. Back flushed everything. Still not getting water to the block. No water in oil either.
    Before I pull the bowl. Is it possible to suck something in bowl that limits water to block but also allows jet to build pressure? I was able to still run up to speed but it wanted to overheating of course.
    Btw. I'm running a Berk JC-A
    Senior Member andyc's Avatar
    Feb 2010
    Valley of the Winds
    Default interesting
    Can we assume you have a gate valve on the pump? If so did we check to see if it was fully open or better yet...does it function? Do you have a garden type hose end on the valve (to run water while on trailer) ? If so.......I would check the water flow/pressure while boat is in the water. Quick way to see by undoing the hose fitting from the gate valve, start her up and see if you have flow. Good to have a short piece of hose with a female end so you can direct hose overboard. 2 people much easier but totally do-able by yourself.
    Pull the intake line that feeds the engine off the pump. blow a garden hose back thru the pump then to the engine. Keep an eye if anything blows out the pump, then back thru the engine and find the restriction. Most people have a problem warming up an engine in a pump boat. you have the reverse issue. FIND THE RESTRICTION into the engine and problem solved. MLAOP> M as an add on. if you are running logs remove the water intake to the logs and check the water flow thru the logs. Be careful not to fill the engine with water. M
    Jul 2016
    Yeah I did all that. That's the strange part. I backflused the entire system. No restrictions. I can flow garden hose water thru system. I also backflused thru jet, and it seems fine. After all that I took it back to ramp and still very little pressure out of pump??? But water is coming out of pump outlet to the block. I inspected gate valve and it's all good. I also removed line to pump and looked into hole which goes into the bowl and it looks clean.
    I'm trying to figure out how I can have bowl pressure but no water pressure coming out of outlet to the block?
    Are you running logs or headers? If headers are they wet or dry?
    Jul 2016
    Runnin logs...
    Looks like I have a bigger issues.... pulled dipstick and I have water in oil....
    Hopefully just a head gasket...
    Quote Originally Posted by Farnorcaljetter View Post
    Runnin logs...
    what engine is in the boat? How far over the full line is the chocolate milk on the dipstick?
    Jul 2016
    454..... Water is probably an 1/8th inch above.
    Feb 2015
    Water in the block probably happened when you back flushed the motor,I always start the motor first then slowly turn the water on till a nice low stream comes out seen this happen more than once on motors.
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    Jul 2016
    Quote Originally Posted by leadslinger View Post
    How is that possible? Are you thinking it flowed over the snails? It seems like it would dump out the back before that.
    Member jetsonly's Avatar
    Jul 2016
    Leadslinger is right. When running logs you cannot run water through it unless engine is running. Water will come in the open exhaust valves. Been there done that. Change oil & filter, run it to full operating temp, might have to change oil & filter again. Problem doing this now is you have another issue to resolve beforehand.
    Jul 2016
    yeah im not following ya? I dont see how water can get into the valves? The water from logs exits on the backside of the snails. Then dumps out the rear. Hows the water getting into the valves?
    Its likely that theres an issue in the jet itself which as you know is the "water pump" for the engine , a simple test would be to run the boat on a water hose if you find that it will not get hot under those circumstaces it will help proof out and diagnose your problem . Barring some oddity in your plumbing ..... didn't see which jet it was ?
    * the water somewhat confusing reversion and ingestion problem into the engine mentioned by others is a problem separate from simple overheating that can occur from running on a hose when the water is turned on prior to engine start or other issues
    Senior Member bp298's Avatar
    LHC
    kind of hard to visualize this. water should be at the bottom of the pan. water doesn't float on top of oil, oil floats on top of water. and it separates pretty quick. just change it and the oil filter and start all over again. most likely nothing wrong with engine unless it's packed full of sand. but I wouldn't run the engine very long with no water flowing out the exhaust because those neoprene exhaust hoses will start melting...
    and to answer your first question, yes there could easily be something inside the bowl restricting flow that you aren't able to see without pulling the bowl off. been there done that...
