Olds 455 Packjet Oil Cooler
Results 1 to 2 of 2
    Sep 2017
    Default Olds 455 Packjet Oil Cooler
    Hey guys,
    I bought a 1973 Glastron with a Olds 455 Berkley Packjet. It has a few issues... The oil cooler is busted, probably from frost. can anyone tell me where I can find a replacement, and what model I should get ?
    Been reading that I should get 2 of these to restrict flow and further cool the oil. Is that what you've done ?
    Thanks !
    Senior Member Mohavekid's Avatar
    Penn Valley, The Sierra Foothills
    I had one of those that burst in a freeze. The solder holding the bottom cover on just burst at the joint. I took mine to a radiator shop and they brazed it back together.
    I don't know about doubling up the coolers. Oil heat is not really the enemy in and Olds. Oil control, particularly in the heads is an issue with the Olds in a boat.
    Good luck.
    Sent from my XT1096 using Tapatalk
