Lube the Wear Ring?
Results 1 to 14 of 14
Lube the Wear Ring?
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Default Lube the Wear Ring?
    So we will not have any method of releasing the pump from the engine to warm up the engine. Just temporarily not continuous.
    I guess there is a way to tap into the wear ring and lube it? I'm sure I can figure something out but anyone have something simple?
    Also the lube the bowl thread. Grease won't do it? The bowl bushing.
    Southwest corner AR
    Doesn't sound like a good idea! Better check this out!
    WT
    WFL Crew!!!
    x2 , definately a no no on a race boat. how about a 12volt moroso control valve so you could just shut off water flow to the motor to get the temp up will at the start.
    New Port Richey, FL
    Run it dry on the trailer?
    dont know how well they worked but i saw several old school rigs installed on the boats years ago, they were a gravity feed oil filled container plumbed into the wear ring area with a manual valve that were supposed to lube the wear ring while running dry. believe they were marketed by tom morrow jet pump repair , could have been others, once again dont know how well they worked, but saw several of them at the races years back.
    had one on my boat, I never used it, but the wearing was shot when I got the boat.
    LaGrange GA
    Don't forget about the water cooled/lubed rope seals. They won't be getting any lube.
    Weve seen a few Jets come thru that were actually drilled and tapped (and equipt with a zerk) thru the pump body and into the W/R for this reason I suppose......
    New Port Richey, FL
    I guess we will shoot water in there with a chemical sprayer or something.
    Was just going to do something while the pump was apart if there was a typical mod to be done.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    OK I must be missing something here? Isnt this what a jetaway is for
    After having one on my Daytona I will always have one.
    The Right Coast/SE-PA
    Quote Originally Posted by earlbrown View Post
    (if) he's using the GFO square graphite packing...as I recal doesn't require water. Great product >been using it for years now.
    The waxy packing with wire in it (ewww)...yes, needs water.
    Southwest corner AR
    I was told to run a water hose in the pump intake and let it flow while running! But still not the best idea! WT
    WT
    WFL Crew!!!
    Not sure but I think he's talking about warming it up at the track, I don't think a hose is an option. I've heard of guys using some type of electric oil heater.
    best option other than a jetaway is to make the drive shaft easy to get out that's what i always do i run wearring clearence super ass tight on ultimate wearrings, it spit out if ever cranked dry.
