who runs Avgas?
Results 1 to 14 of 83
who runs Avgas?
    Senior Member stallion176's Avatar
    Default who runs Avgas?
    If so do you run a top end lube or just filll er up and run er? Any problems with gumming up? need to run it out of gas at the end of the day or???
    In addition to the "lack of lube" thing, I'm told jetting will be different than with gas.
    I have been running av in my motor for the last 12 years with NO problems!No top end lube. No running it out at the end of the weekend! No gumming up NOTHING!Lots of people over the years have told me it hurts your motor thats total B.S!I also have a solid flat billet cam and run ONLY 60wt valvoline racing oil and the cam is still good!Also av is 100 octane low lead! But at sea level it's more like 110. I will continue to run it as long as I can get it.although my motor is 9 to 1 I dont have too I just do it burns cleaner and its not that much more that pump at the dock.
    Quote Originally Posted by pump squirt & BAIL! View Post
    Hell if i can get a full season outta my motor id be tickled. Haha
    Av gas must be different than race fuel then, because with a 9 to 1 motor you'd make more power on pump gas than 110.
    Senior Member 4CE FED's Avatar
    I have run 100% 100LL for 3 years now. 502 with 8.75:1 compression and 9 lbs. intercooled boost. Started off running Marvel but found it was not needed/waste of money.
    I have been running av in my motor for the last 12 years with NO problems!No top end lube. No running it out at the end of the weekend! No gumming up NOTHING!Lots of people over the years have told me it hurts your motor thats total B.S!I also have a solid flat billet cam and run ONLY 60wt valvoline racing oil and the cam is still good!Also av is 100 octane low lead! But at sea level it's more like 110. I will continue to run it as long as I can get it.although my motor is 9 to 1 I dont have too I just do it burns cleaner and its not that much more than pump at the dock.
    Where do you buy it ?
    Are you just running it because you think the super at the dock would have water in it ? At 9:1 if they have premium that would be more than fine and it will make more power with a 91 octane gas. IMO
    Sleeper CP
    Engine junkie
    Thermal, CA
    I've been working with it for years in all sorts of engines, never an issue or problem to date due to the fuel.
    The only tip I have is that it does run leaner, so jet up a little until you find the sweet spot, read the plugs!
    Also if your running an electric pump that is not designed for use with alcohol such as a standard Holley blue, you will need to put a little top end lube in the fuel to keep the pump alive, otherwise you will find that it locks up, or runs real hot.
    BTW running a higher octane fuel like AV in a 9.5:1 or less combo is a waist of HP and money, the engine will make less HP in most all cases.
    Life's journey is not to arrive at the grave safely in well preserved body, but rather to skid in sideways, totally worn out, shouting"....holy shit.... what a ride!"
    A crop duster! Yes I run it because it burns cleaner and I never worry about it being bad.My motor runs cleaner with it but I can assure you I don't lose or gain any power and its cheaper than 91 at the dock in the summer.Now sleeper I know you have somethin to say so come on spit it out! How am I losing by running it in my little 9 to 1 motor????
    Quote Originally Posted by SRP1 View Post
    It's cheaper than 91 octane in the summer! And I run a clay smith manual fuel pump.Btw 91 was 5.00 a gallon at the dock last summer.and it could possibly have water in it! or just be bad that is why I run av
    Fwiw typically a higher octane fuel burns slower. So best results(power wise) come by running only what you need ,plus a little extra for safety/peace of mind. I know I'm not sleeper but 3 peeps told you the same thing.
    Denton, TX
    I do a 50/50 combo 91/AV
    motor is 8.1 on 5lbs of boost.
    We found in a 10.5-1 comp Ford 500 incher, we make more power on pump gas and less timing than AvGas and more timing.
    Typically
