Old School Gale Banks Twin Turbo
Results 1 to 11 of 11
    Dec 2017
    Default Old School Gale Banks Twin Turbo
    I'm getting ready to start installing this setup on my 454 i have in my Checkmate.
    Anyone have a setup like this and willing to give some advise and pictures of their setup?
    Any input or advise would be greatly appreciated.
    Jason
    I attached a picture of a twin turbo setup i found on internet. Doesn't help much but it is of the same one i will be using.
    That is one of the Mercruiser kits that he started selling about the time I was working there, late 70's. They were basically designed to be a "bolt on" kit that went on the Merc exhaust, and provided minimal boost.
    Dec 2017
    Yeah i would like to see if anyone has pictures of how they ran their cooling and oil supply for this setup before i start putting mine on my 454.
    Jason
    Dec 2017
    Default Installation has begun.
    Well we got the boat in the garage and started the installation. Ran into a few problems. I Have to move my Power Steering pump forward 3/4 of an inch so the Mercruiser exhaust manifold will go on (First Picture). Not sure how i am going to do that, I am already using the front pulley groove for that V-Belt. 2nd issue is that Oil supply inlet for the Turbo seems to be missing a part (2nd Picture). Not sure if this is available or if i have to fabricate one. Any input would be helpful. The other pictures are of my progress.
    Dec 2017
    Quote Originally Posted by Maxxum229 View Post
    More Progress pictures
ID:	1004962   Click image for larger version.
    Member Tahoe540's Avatar
    Jul 2016
    Sparks, NV
    Keep the pics coming. Following your thread on OSO too. Did you buy a blow through carb?
    Your photo shows the oil drain side of the turbo, not the inlet which is threaded 1/8" npt.
    Quote Originally Posted by Tahoe540 View Post
    It's not a blow through system.
    Dec 2017
    Cool thanks.
    Yeah i figured that out after i posted.
    Looks like i will be going with Full Hydraulic Steering so i can get rid of the power steering pump, then the manifold will bolt onto the engine on the port side.
    Could be tho with alil mod here mod there😁
    Dec 2017
    Default Fabricating the exhaust.
    So what do I need to be sure I do or have done when I fabricate the exhaust from the turbo to the transom.
    It doesn't line up. Any input or suggestions?
ID:	1008154   Click image for larger version.
