Interior Upgrade Leadslinger
Results 1 to 14 of 37
    Feb 2015
    Default Interior Upgrade Leadslinger
    One of the only PINK boats to run the lower River not mine but my kids and it's also a Predator but from Neil back in the day MED lay up, sister boat to "Green with Envy" and it's getting a full interior restore And new fresh pump and fresh 468 13.5 to 1 motor it had full carpet, bench seat,2 batteries had no alternator,huge fuel filter, tank selector 2 miles of wiring the engine dam was made of wood and 1/4 aluminum it had gas tank side covers and 2 -22 gallon saddle tanks and who the hell needs that much gas, well today boat got gutted and parts are being ordered cant decide if the floor should be sanded and Prestec or shoot gel coat like a dark grey, going full engine stranger center tank ,moving the motor forward total rewire, rear alternator center console This thing went on a diet. More pics as it gets done
ID:	1006242   Click image for larger version.
ID:	1006250   Click image for larger version.
ID:	1006258   Click image for larger version.
ID:	1006266   Click image for larger version.
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    Feb 2015
    Hitting it with some 80Grit on the drivers side tunnel, going to take awhile this boat was layed up for carpet and no finished floor at all, we have some sanding to do,,,,
ID:	1007450   Click image for larger version.
ID:	1007458   Click image for larger version.
    May 2014
    That will be ALOT of sanding!! Thought about doing that to my stringers but took the easy way out. Carpet. It'll be worth it, especially in that boat!
    Feb 2015
    Kept telling the Kid to re-carpet but wants the bare floor look the sanding will be done he says tomorrow and ready for some product to get shot on.
    Sep 2009
    Walled Lake, Michigan
    Default prestec
    I like the idea of Prestec or similar clear product over grey or solid color. Just my opinion. Looks like a nice project that is going to be even nicer when it is completed.
    Darin
    Margaret Thatcher once said The trouble with socialism is that eventually you run out of other people's money.
    Feb 2015
    Right at 10 hours of sanding one person Kid is wishing he did carpet I bet,,,,,
ID:	1007682   Click image for larger version.
ID:	1007690   Click image for larger version.
ID:	1007698   Click image for larger version.
    Feb 2015
    Well at 12 hours of sanding it's half way done and it sits hard to explain that you only have 12 more hours and your done ,,,no more sanding . My dad would of had me do this with a block and a piece of sandpaper while the whole time he would of had a bitchen palm sander in his back pocket,KIDS
    Feb 2015
    Default Rough cut bulkhead
    Got them knocked out need final sanding and some wee bit adjustments going to look good with some clear Press tech really opened up the boat and brought it up to date.
ID:	1013041   Click image for larger version.
ID:	1013049   Click image for larger version.
ID:	1013057   Click image for larger version.
ID:	1013065   Click image for larger version.
    Apr 2010
    Rocklin, Calif.
    Man that's A lot of work..are you going to put some floatation under the deck?
    I don't mean water wings
    Feb 2015
    Actually there were 2 life jackets from I think day one that were behind the bulkhead that got cut into when we started cutting, one on each side so now there wont be any hidden articles plus 10 pounds of sand and easy to get the water out, my old 82 Daytona had a huge bag of foam peanuts and it was so wet and moldy just nasty had to be factory no way you could of got them in there this one turned out good plus now you can store a canopy on the side no problem and looks more up to date
    Feb 2015
    Default Dowel
    Well floor is 99% sanded, Dowels are resin in and sanded need to start the side bulk heads then on to the Product getting sprayed .
ID:	1020930   Click image for larger version.
ID:	1020938   Click image for larger version.
ID:	1020946   Click image for larger version.
ID:	1020954   Click image for larger version.
    Feb 2015
    Default Motor parts
    The motor begins and the parts start to roll in ,Only the good ones .
ID:	1021226   Click image for larger version.
ID:	1021234   Click image for larger version.
    Feb 2015
    Gunnel bulkheads fab up and ready for install that took a bit for a proper fit and correct clearance not to touch the fiberglass of the boat needs to have clearance or you'll have crazy stress cracks ,We had to cut out the old ones out to get the gas tank out and I have to say they were not installed very well to say the least Glass was poor quality we really just pulled them out and a little grid job . It's done right now ,,,I kept the template so anyone else needs it ask,,,,
ID:	1023115   Click image for larger version.
    Feb 2015
    Glassed in,,
ID:	1023475   Click image for larger version.
