Daytona help
Results 1 to 6 of 6
Daytona help
    Feb 2015
    Default Daytona help
    Here's the deal kid has a 19 Daytona clone need to find out where to set the motor from back of transom (inches)
    SPECS
    Med lay up around 500-550lb hull
    Flat bottom keel
    HP around 700-750
    American turbine b/c cut and inducer
    boat will have full stringer 2 seats, 12 gallon center fuel tank, cast block, aluminum heads bare minimum for weight.
    Any formula on this would help to get close and save some time.
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    Senior Member poncho's Avatar
    SE Mass/Bering Sea
    Quote Originally Posted by leadslinger View Post
    SPECS
    Flat bottom keel
    HP around 700-750
    Tony has been setting up 19 and 21's for a long time, I'm sure he could be a lot of help.
    Jet Boat Performance Boaters! | SkagenBoats.com
    Feb 2015
    Quote Originally Posted by poncho View Post
    Thanks, I will give him a call ,Still open for more suggestions on the forum.
    Mar 2010
    Clarksville, TN
    I ran mine at 30”.
    Feb 2015
    I ran mine at 30”.
    Now were talking ,You had a close set up to these specs
    Mar 2010
    Clarksville, TN
    It was at 34” when I started and the boat wouldn’t clean up, really wet. Moved it to 30” and made a huge difference. My boat is pretty light and single seat race deal but it will give you a idea.
