stuck throttle and pump cable
    Nov 2011
    Holiday Florida
    Default stuck throttle and pump cable
    i have a 76 Sutphen Jet boat with a stuck throttle and pump cable...can not push the lever forward only backward...
    Any advice to lubricate (which I hope would free the cables) would be helpful since it does not have a cable but a steel rod that slides back and forth (I think)
    thanks...
    Aug 2012
    Quote Originally Posted by barefootin View Post
    thanks...
    Personally, I wouldn't try to cut corners here, replacement costs are very reasonable and an easy DIY project.
    Quote Originally Posted by 1320 View Post
    I agree👍 if you know the cable is fairly new but it rusted you can slide a foot of 5/8 or 3/4 rubber hose over one end and hose clamp it to the cable, fill the hose with oil then put a shop air hose fitting in the other end and clamp it down tight. Regulate shop air pressure down to around 30psi and with air fitting end of hose pointed up so all the oil in hose is in the bottom, put air pressure to it and it'll push the oil into the cable and out the other end. Cheap temp fix
    Feb 2015
    KROIL this is the stuff to use but keep it to yourself I dont want everyone on PB to find out.
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
