Ford t-stat housing discontinued ?
Results 1 to 14 of 20
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    Default Ford t-stat housing discontinued ?
    So I am told the Ford t-stat housing is discontinued. What are you to use if you want a t-stat ?
    Senior Member wajetboy's Avatar
    Auburn, WA
    u can use a modified chevy one. can you put a chevy part on your boat? its blue thunder all over again.
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    Quote Originally Posted by DaytonaTunnel View Post
    You install a bypass pressure regulator on the pump inlet. Then you take a t-stat and drill two 3/16" holes in the t-stat flange.
    We "Plate" the "T stat" opening (9 bucks) from us Glenwood etc then use the Two large pipe threaded holes at the front of the intake on Ford and aft mkt intakes Tom
    Jet boat service
    Sebastopol Cal.
    You are correct. The Ford t Stat housings are no longer available. You can't do the thermostat / pressure relief trick with out the housing. I am working on a piece right now that will solve the problem, have to write a CNC program for the prototype. My son is going to do that for me. We discussed this just last week. I'll keep you posted. Jim
    The Earth
    Blog Entries
    24
    We are casting the Ford Divider Tee outlets right now (old L&L tooling reworked). (If that's what you're referring to). Should be ready to sell in approx 30 days.
    Senior Member GottaJet's Avatar
    Santa Clarita,CA
    My boat has been running for thirty years now with no t-stat just the old gate valve set up with no major issues (knock wood) should I really worry about something like this now?
    Shhh!! Can you hear that?? GJ
    Enumclaw, WA
    That's the one I'm after, 30 days away ?
    Senior Member sdpm's Avatar
    You mean like this one? Looks like I have the only "NEW" one left in existance. How about $750.00
    OK,OK how about $35.00 plus the ride.
    Newton Ks.
    Quote Originally Posted by GottaJet View Post
    No.
    I have run the same setup, the same 30 years, without issue.
    H.L. Mencken
    The Earth
    Blog Entries
    24
    Yes approx.
    Unfortunately some of the tooling was damaged before I got ahold of it, wooden gates broken on plate etc. But that is being fixed. Once I get the castings machining them will not take long.
    Enumclaw, WA
    Thanks for the offer SDPM, but it looks like I found what I need closer to me. If it doesn't work out I will call on you. Thanks again !
    The Earth
    Blog Entries
    24
    These housings are in by the way. Forgot to post it sooner here.
    Some damn nice castings rexone.
