Bulkhead fittings
Results 1 to 9 of 9
Bulkhead fittings
    Default Bulkhead fittings
    ISO long bulkhead fitting in #10 in aluminum all I can find is stainless and I don't want to pay 90 bucks
    Feb 2015
    CP Performance - Super Nickel Male AN Flare Bulkhead Union
    these are like 15.00 bucks then order the bulkhead nut with it for like 3 more bucks they have different colors
    CP Performance - Super Nickel Bulkhead Nut
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    I already looked there those are not long enough
    Feb 2015
    whats the total length you need,thickness of the bulkhead
    the standard bulkhead fitting is 2 7/8 total length the problem is the fitting goes thru the transom and I can put the nut but there is not enough to put the hose end fitting on and tighten up I need another inch of shoulder to go thru the transom then every thing will tighten up
    Feb 2015
    ya that's the best deal Ive found from eddies
    Is $10 cheap enough with the nut???
    https://www.summitracing.com/int/sea...5%2B4294947249
    NOT LONG ENOUGH that what the post is all about lol
