Motor placement.
Results 1 to 14 of 15
Motor placement.
    Nov 2017
    san jose
    Default Motor placement.
    I added a jet-away to a stealth now it seem I need to pull the motor back about an 1” to 1 1/2” or forward about the same (can’t seem to find or have a driveline made where I would not Have to move it). Motor sits at 24” from transom now would it be better to set it back or move it ahead? Thanks.
    Apr 2010
    Rocklin, Calif.
    Look into Lenco drive shaft
    Feb 2015
    East county drive shafts makes them and there only 4 miles away from Lenco ,hell use your existing shaft and make sure you got the 1/4 inch play in there, around 120/160 bucks
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    Nov 2017
    san jose
    Quote Originally Posted by leadslinger View Post
    With the driveline I have its 13.5” end to end I need 9”, driveline shop said they could not make it 9” needs to be about 10.5 end to end, that will slide the motor forward approx 1.5” if I buy a 1350 they measure 8” end to end, if I can’t get a 9” would it be better to slide the motor forward or back? Or does that small amount matter, Thanks.
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Short Drive Shafts
    February 14, 2018
    Hello People
    Water
    This company has mad dive lines for me over the years and they are shorter than 8”
    https://www.driveshaftpro.com/gardena
    And he balances the shafts
    Willis
    149 BGJ 156.74 MPH @ 1000'
    Apr 2010
    Rocklin, Calif.
    Quote Originally Posted by waterfun#1 View Post
    Bobby..If Papp set that boat up I wouldn't make to many changes
    Feb 2015
    ECDS cuts the ends off and re welds and balances and new shaft it's pretty straight forward
    Feb 2015
    Heres a 6 inch shaft correct way to measure others measure a way only Einstein can figure out and you still need a 1/4 inch play or bye bye thrust bearing and crank.and I have a pic of the last one made for me a tad longer.
ID:	1010690   Click image for larger version.
ID:	1010674   Click image for larger version.
    Apr 2010
    Rocklin, Calif.
    Table looks good but tired
    Nov 2017
    san jose
    yes, I do not want to move the motor I just can’t find a 9” end to end shaft.
    Nov 2017
    san jose
    I brought the one I have in to a shop to have the ends cut of and shorten but the best the guy said that it would need to be 10.5”
    Feb 2015
    I would buy a new one but kinda broke from sitting home with this injury, the boat is 100% done just waiting to splash and still looking for a gently used Life Line jacket ,back to the drive line guy he needs to stick the yolk in and measure the remaining distance get a overall measurement minus a 1/4" and have one made easy peasy
    Feb 2015
    End of metal to end of metal is how you measured it ,Am I correct ?
    Nov 2017
    san jose
    No, I was calling end to end from the flange that bolt to the PTO to the slip yoke where it would butt the snap ring on the jetaway, I think the motor is moved back to accommodate a back seat so moving it forward is not an issue, Thanks.
