Olds 455 jetboat Terminal block mounting
Results 1 to 2 of 2
    Default Olds 455 jetboat Terminal block mounting
    My neighbor has a a jet boat that he is working on- Just installed a DUI HEI-style distributor.....His Terminal block above the bellhousing is just hanging there. On my 460 it mounts to a cast-in spot on the bellhousing....
    Does anyone have some pics/suggestions? I can fab up a bracket, but I was thinking someone must make a nice bracket...
    Default Some one??
    Quote Originally Posted by cvxjet View Post
    Yep, step up, and make it as nice as you want it.... I've seen those junction strips mounted by the upper bellhousing bolts, must be a couple little "L" brackets missing....
    Ray
    LOUD BOATS SAVE LIVES
