Berkeley Pump Rebuild - need help diagnosing problem - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 18 of 18
  1. #15
    Default Great results...
    I'm glad your jet rebuild cleared up most of your issues... That said, you also mentioned a new interior was installed while the boat was down... OK, but in the future try to limit the changes to ONE AT A TIME.... True, the interior refresh shouldn't play a role in the performance end, but slight/small changes in boat balance can effect performance and make you think other changes made the difference...
    Have fun, be safe, and wear a vest at speeds above plane, especially if you are alone....
    Ray
    LOUD BOATS SAVE LIVES
    Apr 2012
    Since you have the 325hp BBC, you 99% probably have the small port heads (peanut port). Those things wont rev much past 5K. They just dont flow enough air. They hit a "wall" around 4800 and depending on your pump setup and timing and cam, that's about all you'll get. I know because I run them too. So your RPMs for that engine seem right to me.
    "I'd love to help you out wags, but there is larger issue concerning breast cup sizes on another thread that we have to work thru first. This subject suddenly became a non issue." - GN7
  4. #17
    Member ezstriper's Avatar
    fredericksburg, va
    those motors only good for 4500-4600, drop like a rock after that
    These posts are almost from a year ago?
