Welding..
Results 1 to 14 of 15
Welding..
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Welding..
    Anybody know a good welder who can weld a oil pickup onto a cast oil pump for me. I've called about 10 places so far and nothing. I guess the task of welding a steel pickup onto a cast pump is a tricky one. Anybody recommend a good welder in the south OC area?
    Redding, CA
    It takes about 15 seconds with a wirefeed.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Senior Member Pattymelt18's Avatar
    gO TO CLAY SMITH CAMS HE WILL SET THE HEIGHT FOR YOU ALSO .THEY ARE IN BUENA PARK.
    031 RIVER4FUN's Avatar
    Quote Originally Posted by Pattymelt18 View Post
    X2.
    I also got a blue printed oil pump from them
    Paul Pfaff
    #55
    TJS
    TJS is offline
    CT
    This is cake. Once again I am on the wrong side of the country.
    T.J.
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    I can do it...
    San Clemente, Ca
    Paul Pfaff
    San Clemente, Ca
    I'm going up to Bob McKray tomorrow to pickup a set of heads for a buddys build, he said he could do it while i'm there. Thanks.
    So Cal
    Shaun, you entertain me. You started your thread with a question and finished it with your own answer.
    TEN THIRTY ONE RCB19's Avatar
    Your fired!
    RCB
    Default Bracket, not welded!!!!
    Have a bracket welded on the pick up. DO NOT weld the pick up into the pump. The heat required may distort the pump body. Have someone weld a bracket that bolts under a couple of oil pump cover bolts......I thought welded in pick ups were loooonnnnggggg gone.......Is this an "out of the box" pump?? Gee, I thought you were trying to not make the same mistakes again????.......Ray
    LOUD BOATS SAVE LIVES
    Banne'd Cobra1's Avatar
    Had a clay smith in my dodge, darn good cam.
    San Clemente, Ca
    Talk to Stefs, there instructions say to drill out the pump to 49/64ths and to have the pickup welded. It does have a tab on the pickup.
    Pumps a hi-vol melling, already blue printed it.
