big problem..help
Results 1 to 14 of 15
big problem..help
    Senior Member beerngasoline86's Avatar
    hacienda heights ca
    Default big problem..help
    anyone ever heard of a head gasket leaking and the compression blowing threw from one cylynder to another creating a grove between the two?
    Olympia, Washington
    Yes it happens all the time if not caught when it first blows, didn't you notice it missing ?
    hacienda heights ca
    no not at all the only reason i notised it at all was cause i finally lost a spark plug? is it fixable? weldable?
    Douglas, MA
    fireslotting right?
    is this posted over in the dyno section too?
    Olympia, Washington
    A groove in the block or the heads? How deep? The depth is the killer if to deep to deck out. If in the heads are they cast or aluminum?
    can sometimes be welded. take it to a machine shop.
    Senior Member blownjet's Avatar
    Winchester
    Quote Originally Posted by beerngasoline86 View Post
    just blew a head gasket over easter weekend. it blew between #4 and #6 cylinder, burnt the head (aluminum) had it welded and looks good, call bob mckray in mission viejo (949) 458-7087
    hacienda heights ca
    the grove in the block isonly 1/8 deep but the piston stays well below that...and the heads are cast...
    Olympia, Washington
    Check to see if you can have the block decked. Are the heads ate up also?
    hacienda heights ca
    yea the heads are worn in the same location..
    Senior Member Cobra 02's Avatar
    Montclair
    I say you junk it lol..... Thats my opionion
    Apr 2009
    Default blown head
    I would say it's too much beer!!!! & not enough 114 oct gas
    hacienda heights ca
    the gas would cause that??
    Q.C./Big River
    My 509 is in the shop right now for the same reason. Not quite an 1/8" groove (caught it before it got that bad) but definately the same situation. Did you crack the head as well? I did. It all depends on how severe it is. Sounds like it can be fixed. Where are you located? I can recommend a good shop to get it done at. Oh yeah, plan to go to a larger piston too. My deal was caused by bad gas that sat in the tanks for over a year outside. I was going to drain them but just added some 110 and thought it would be OK, expensive mistake!!!
