carburetor size?
Results 1 to 5 of 5
carburetor size?
    May 2017
    Default carburetor size?
    Would a holley track warrier 850 be good for a mild built 454 chevy engine? i can not find a carburetor section.
    Senior Member SPECTRA-SANGER's Avatar
    Sep 2016
    I run a Holley 750 on a 10.5 to 1 BBC, 990 heads and fairly mild cam, looking at around 560 lift on intake and a Vertex Mag. Motor spins up to 5600 with a 3 blade prop all day. I had CJ engineering set the carb up years ago and I have ran this combo since 95' no issues.
    Senior Member stc315's Avatar
    Yuma, AZ
    It will work (as mentioned, I would have it tuned by CJ) but BBC's seem to run better with 750 in a boat. BBF's seem to like 850 better. Just my humble experience.
    Too much horsepower is almost enough!!!
    My boat is fast.....on Craiglist or EBay.
    I've been 340mph+ with a boat........In the back of a C130!
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Carb size
    Quote Originally Posted by buck sharp View Post
    June 19, 2018
    Hello People
    John will have all your answers and carbs you will need.
    C & J Engineering
    14130 Alondra Blvd
    Santa Fe Springs CA 90670
    562-229-0222
    Willis
    149 BGJ 156.74 MPH @ 1000'
    Member ezstriper's Avatar
    fredericksburg, va
    I think a 750 would be a better choice
