How deep should jet be under power?
Results 1 to 6 of 6
    Member Tahoe540's Avatar
    Jul 2016
    Sparks, NV
    Default How deep should jet be under power?
    Still learning about my jet boat. I happened to be in the back seat and looked at the jet and was surprised to see the jet was just about all the way out of the water. Is this how it is supposed to be?
    Feb 2015
    Need a plastic bushing in the pin,Looks fine
    Slinging Lead on and off the water for over 40 YRS
    82 18' Crusader Tunnel SOLD ,
    00 23' Mako 232 fish killer,SOLD
    78 19' Eliminator Daytona SOLD
    16 19' Predator/Cheyenne
    Jul 2016
    Sparks, NV
    I saw that and thought should that have a bushing LOL. Guess it does. Thanks
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    The thrust is performed inside the pump. By accelerating a mass of water. The nozzle being out of the water helps flow more water through the pump by probably a tiny percent but helps for sure at slower speeds.
    From 2009 https://www.performanceboats.com/jet...out-water.html
    QE 439 Twin Turbo
    Looks like the divertor oring is leaking at the bowl adapter also
    Jet drive thrust is basically the same as Rocket thrust......Back in the early twentieth century, there were people who would argue that rockets would not work in space/vacuum- Nothing to push on!
    The rocket- and the jet drive both work on mass/reaction; Sit on an air mattress with a pile of rocks- then start throwing the rocks...the mattress will move in the direction opposite the the rocks....Mass expelled in one direction creates thrust equal to- but opposite to that expel-lation....?
    The ejected water mass is not as massive as the boat, but it is moving at approx' 60-80 mph when the boat is moving at 20-30 mph......in the opposite direction.....
    (Just so you know, I recently caught myself on fire....So I'm not that fart- whoops!.....smart)
