When to go from 3 point to 4 point engine attachment
    Member Tahoe540's Avatar
    Jul 2016
    Sparks, NV
    Default When to go from 3 point to 4 point engine attachment
    I have what seems to be a pretty stock 454 with oval port heads, flat tappet cam and dual plane intake. My plan is to use my ported 088 heads, matched dart intake and a decent hydraulic roller cam from my offshore motor. I will probably put new pistons in depending on what I find. Would these upgrades warrant me to change to a 4 point rail style system? Other attachment system? The motor is in a Hallett Daycruiser.
    bullhead city
    I'm over 500hp and haven't changed yet but I want more hp so I will soon, motor has been in for 4 years took out stock 320 hp
    kenny nunez
    Oct 2014
    Kenner, La.
    Default 3 Point or 4 Point
    A late friend of mine was killed when the 454 came loose and crushed him under the deck in his 18’ Mandela. I admit he was drunk and he was doing stupid things and ended up hitting some rocks. I am sure a 4 point would have stayed together.
    bullhead city
    I would put it in and run it, if it starts to pull bolts change it out
