Jet drivelines
Results 1 to 3 of 3
Jet drivelines
    Rancho Cordova. CA
    Default Jet drivelines
    Got a question...what horsepower level requires the 1350 driveline assy? Need to replace my old one.
    the caps are loose and can spin in the h-bar!! I am running a pump gas 496 chevy 10.2 to 1 and get 5700rpm on an A impeller.
    thanks for any feedback
    You're fine, i spin a aluminum 1310 shaft over 7400 on 1100ish with solid Spicer joints
    Rancho Cordova. CA
    Thank you sir!!!
