Want some more ET from your jetboat?
Results 1 to 6 of 6
    okie, lake Texoma
    Default Want some more ET from your jetboat?
    Dont listen to the haters, be sure to look up Duane Oblander @ Jet Pump Parts & Service & Racing Jets - Hi-tech Performance, inc. He is "top shelf" if you want the best from your pump. Check out the new "Snoot" and Race Nozzle package with the Elliptical Nozzle and his own design Racegate neutral/reverse bucket. The Elliptical inserts are available 2.90"--- 3.250" The bends on the bucket are removable for racing -or- put them back on for reverse @ the lake. The Racegate will fit just about any configuration as it has an arm on each side-- just cut off the one you don't use.
    Several of these have been tested and "every" one picked up ET with them. The gain in E.T. is from the properties of the elliptical nozzle.and the configuration of the race nozzle.
    The 0828 will be sporting this assembly in 2019
    H8-2-W8
    [email protected] first pass
    okie, lake Texoma
    H8-2-W8
    Tell Duane to get on a long insert and bucket for place divertor😁👍 would love to 2step against one of those 😈 looks like itd seal up enough to not hose the boat itself down at a 2k+ rpm
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    I had that on the Red Pearl 3 years back. Didn't get a chance to run it.
    QE 439 Twin Turbo
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Natural Oval shape Nozzle - Increase Et
    November 14, 2018
    Hello People
    Hass
    That “neutral oval shape nozzle” to increase ET. Is there any data to verify the claim
    Willis
    149 BGJ 156.74 MPH @ 1000'
    okie, lake Texoma
    Quote Originally Posted by willis View Post
    November 14, 2018
    Hello People
    Hass
    Willis
    I have two friends with data on their boats, one reported that he was 2 tenths quicker from zero to his max mph. The other reported 3 tenths and 3 mph to the 1000ft. There have been others as well- but they didnt report to me directly.
    Haven't heard of a single one that didn't get a gain with it.
    H8-2-W8
