[Question] Rehashing the jet-a-way question
Results 1 to 9 of 9
    Sep 2017
    Default Rehashing the jet-a-way question
    Hey guys I just bought an old Kona tunnel drag because I have a 460 ford sitting on the garage floor out of an old boat, 12.75:1, 736 inch lift type cam, fully ported, yada yada-----. I'm getting old now and wanna know if I need to spend the money on a jetaway or is this little sled of a boat safe in case of catastrophic shut down. Boat will only be used in case the neighbor drops his in the water and he needs his doors blown off LOL.
    Short and stout nunes792003's Avatar
    Nor Cal
    Default Ass Over Teakettle
    Quote Originally Posted by rlc707 View Post
    ric707 just food for thought, I remember an old timer telling me personally no matter what you do you need to always think about and respect what these machine's can do in a slit second. SAFETY FIRST! Like he also said guys spend thousand and thousand's of dollars on their boats and jump in them with a simple standard life vest and no jetaway. What it boils down to is at which speed do you feel your going to be okay if the thing locks up and pitch's you and or you and passengers out of a boat? me personally I would much rather stay dry!
    Sep 2017
    That's the answer I was looking for. I know I'm to old to play skippy across the water. Anyone happen to have on old one laying around they wanna sell?
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Check with Duane at HITechPerformance he gets some used ones in sometimes. Also another cheap insurance is pull and inspect your loader and bolts every trip to the water.
    Sent from my iPad using Tapatalk
    It's a lot easier on the boat too. Many light weight boats break-up when they make that sudden and unexpected turn.
    small block jet 2sangers's Avatar
    Lexington SC
    Speaking from experience, a jet a way will not stop a light weight Sunkist tunnel from turning on hard shutdown. They do make tuning / warming the engine on the trailer much easier though.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    There is no add on device that will keep a hull design with bad shut down characteristics from doing it's thing. Jet a way will help and as mentioned good for warming up out of the water. Pop off helps shut down at really high speeds.
    The best thing to do is buy a hull that is forgiving to hard shut downs.
    QE 439 Twin Turbo
    I totally agree, and well explained.
    New Port Richey, FL
    Thanks Jim
    QE 439 Twin Turbo
