Twin Turbo LS 19 Daytona build
Results 1 to 14 of 15
    Member ezstriper's Avatar
    fredericksburg, va
    Default Twin Turbo LS 19 Daytona build
    Just picked up a 78 19 Daytona jet, going with a twin turbo LS(been racing a Turbo LS drag car for years). Have a couple of questions, what oil pan are you using ? the pump is set way back so nothing under engine, also the BB in this was way forward(to me) 30.5" transom to rear plate, 14" driveshaft. Would like to move engine back to make back seat somewhat useable. Any advice would be welcomed, thanks Rob
    Sep 2014
    Subscribed! I'd really like to build an TTLS river boat.
    small block jet 2sangers's Avatar
    Lexington SC
    Default oil pan
    GM 12640748, 2010 -2014 SS, Zl1,Camaro or G8 pan works great in our Sunkisst tunnel. Holds 8 quarts too. Cheap on ebay.
    fredericksburg, va
    Quote Originally Posted by 2sangers View Post
    thanks, have a Fbody pan that just picked up, have not mocked up engine in boat yet, waiting on ft engine plate, pics show what I'm starting with...
ID:	1030825   Click image for larger version.
ID:	1030827   Click image for larger version.
    Same pan I've been running👍 ran a g8 pan on mighty mouse tunnel as well, never once had a oiling issue. I run 7qrts in them
    Run the driveshaft you've got, set engine where driveshaft makes ya and call it good. Motor to far back in a Daytona isn't a good thing
    Quote Originally Posted by N2otoofast4u View Post
    Lake boat , no rivers 😜👍
ID:	1030837   Click image for larger version.
ID:	1030841   Click image for larger version.
    fredericksburg, va
    thanks, talking to greg shoemaker on setup now, going to mock up engine and see where we are at, wanting to run back seat
    Lexington SC
    Default back seat
    I think you can with the driveshaft you have. My 19 Daytona had a back seat with a BBC and no setback on the pump.
    Aug 2009
    O.C. & Lost Lake
    Listen to Gregg. He will help you keep your hair dry. There is a reason they run motors forward in a fast Daytona. That motor is light and if makes as much steam as the potential it has, you should have a rocket.
    fredericksburg, va
    Gregg said I could move back to where bell housing cleared the pump support plate and be fine...
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Quote Originally Posted by ezstriper View Post
    Just picked up a 78 19 Daytona jet, going with a twin turbo LS(been racing a Turbo LS drag car for years). Any advice would be welcomed, thanks Rob
    March 6, 2019
    Hello People
    The jet drive looks like a Miersch intake and Aggressor pump? If so, the hull needs fixing - J Bennett
    Do have a data system to tell you what PSI or Vac you're generating?
    What kind of performance are you looking for, 120, 140MPH plus?
    Willis
    149 BGJ 156.74 MPH @ 1000'
    fredericksburg, va
    Quote Originally Posted by willis View Post
    March 6, 2019
    Hello People
    The jet drive looks like a Meirsch intake and Aggressor pump? If so, the hull needs fixing - J Bennett
    Willis
    Ok, I'll bite...hull needs fixing ? not looking for anything performance wise, just a mess around creek boat. Yes we are going to run megasquirt for the EFI(we run it on a no-prep car my son drives) so yes will have data. Currant plans are to keep boost low @10-12 that should put us @700-750hp
    Gardena, CA
    Default Hull fix Meirsch intake
    March 7, 2019
    Hello People
    ezstriper
    All of those early Miersch intakes will create a low spot on the inlet side of the jet intake and the boat loses vacuum that suggest the water flow is not “hugging the hull” into the suction piece.
    B1 Racing, Anaheim CA, Chris Starkweather has the new versions of the Miersch intake with the fix.
    But you said it’s a lake boat and you don’t worry about performance.
    The data I’m talking about is not the engine ECU but the how the boat is hooking up and the performance of the jet drive.
    Looking at the graph, the line that’s going down and stays down is the “hull fix”, before the hull fix, the line would go down, but as the speed increased it would start to rise.
    By the way, Greg Shoemaker, can answer all the questions about the intake fix on the early version Miersch intakes.
    Willis
Name:	2017 Bennett Hull.jpg
    fredericksburg, va
    March 7, 2019
    Hello People
    ezstriper
    Willis
    thank you, Rob
Similar Threads
  1. How to Twin Turbo LS Engines
    By Huffa in forum Jet Boats
    Last Post: 02-25-2016, 01:13 AM
  2. BMW twin turbo Daytona 19
    By 1Luke in forum Jet Boats
    Last Post: 11-17-2015, 01:23 PM
  3. Replies: 16
    Last Post: 10-01-2013, 07:26 AM
  4. Twin turbo LS powered Tunnel
    By lmg in forum Jet Boats
    Last Post: 06-01-2012, 11:20 AM
  5. greg, how did that twin turbo ls sbc tunnel end up runnin?
    By IMPATIENT 1 in forum Greg Shoemaker
    Last Post: 02-24-2010, 03:08 AM
