Jacuzzi WJ impeller and wear ring
    Aug 2014
    Phoenix
    Default Jacuzzi WJ impeller and wear ring
    I have a 21' Hondo day cruiser with jacuzzi JW with place diverter and olds 455. Engine runs very good with stock build except comp cam, eldelbrock torquer intake and Holley 750 pumper carb. Seems the boat is more sluggish than it used to be and turning more RPM than usual. I turn 3200 -3400 all day long minimum just to get on plane and cruise and no less. Boat tops out at about 4700 RPM. Not sure about speed. I have never checked.
    I was going to check wear ring gap. I understand I can do this through the access cover and should measure about .010". I believe it has a SS wear ring from Jet Boat Performance. My question is if the gap is to large what do I do then? Can I have a wear ring custom made to match the outer diameter of the impeller? Can I buy an "A" cut impeller anywhere? Any advise would be great.
    Best bet would be to go back to Tom at JBP and tell him the story! They make oversize wear-rings for this problem if in fact it is a loose fit it can be fixed.
    Sep 2014
    Post a picture of the boat. I have a very similar setup I think.
    Aug 2014
    Phoenix
    OK I will give Tom a call. I understand but correct me if I am wrong there should be 2 clearances to check...one is the outside diameter gap between the impeller and inside diameter of the wear ring. The second is the gap between the impeller and the pump housing.
    Thanks for the help. I broke my phone and got a new one so I will get some pics of the boat as soon as I take it out again.
Similar Threads
  1. wtb "a" alluminum impeller for jacuzzi wj
    By 78hallet in forum Michigan Hot Boats
    Last Post: 06-04-2013, 05:56 PM
  2. Impeller Skirt Wear Ring Help
    By pilot940 in forum Jet Boats
    Last Post: 03-14-2013, 04:12 PM
  3. Jacuzzi WJ Impeller Nut
    By Storz in forum Jet Boats
    Last Post: 02-01-2011, 06:36 PM
  4. jacuzzi wj w/adapter ring HELP
    By bbcsouthwind in forum Jet Boats
    Last Post: 09-28-2009, 10:38 AM
