Twin Turbo LS Daytona build
Results 1 to 7 of 7
    Member ezstriper's Avatar
    fredericksburg, va
    Default Twin Turbo LS Daytona build
    redoing a 78 daytona jet, twin turbo 6.0, holley EFI
ID:	1035375   Click image for larger version.
ID:	1035377   Click image for larger version.
ID:	1035379   Click image for larger version.
    okie, lake Texoma
    nice--- following
    H8-2-W8
    [email protected] first pass
    small block jet 2sangers's Avatar
    Lexington SC
    Doing the same thing to my 21 this winter. Got my Terminator X on the way for ecu. Are you going to install a fuel pump in each saddle tank? Did that boat come from SC? Keep us posted.
    fredericksburg, va
    Using ternminator X as well, came from Ga, guy had bought in Fl, was told was raced in Mi, but have no idea, any info would be great. Using 1 big Magnafuel pump, Y from tanks with shutoffs
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Awesome Magnafuel pump will put out 100 + PSI of fuel pressure?
    QE 439 Twin Turbo
    fredericksburg, va
    only need 43, using it on a 1500hp car on E85 now
    fredericksburg, va
    Default update
    got water all plumbed, IC, exhaust done, still have to do fuel system, but moving along
ID:	1035521   Click image for larger version.
ID:	1035523   Click image for larger version.
