can't change my oil filter
Results 1 to 14 of 23
    Default can't change my oil filter
    Do you guys have to jack up the motor to change the oil filter?
    Can i buy one that's a little shorter?(I think 1/2 in shorter would work)
    Do i need to run a marine oil filter or is auto fine?
Name:	oil filter.jpg
    Why don't you just put a Chevrolet in it! Just kidding! My first thought would purchase a remote filter and be done with it.
    If thats a Ford, you can find the angled filter adapter, was used on the trucks, and retains the stock filter, but at a diferent angle.
    Las Vegas, NV
    they make a 'shortie' filter that makes it much easier to change.
    I'm baaaaack... hkunz's Avatar
    Lake Havasu
    No need to change it, just poke a hole in it with a screwdriver to get the old oil out
    It is impossible to defeat an ignorant man in argument. -William G. McAdoo, lawyer and politician (1863-1941)
    07 Advantage X-Flight 600 SCi Bravo 1 XR
    04 Cheetah Scorpion 6.2 Bravo 1 - SOLD!
    96 Donzi 21' 454 Bravo 3 Medallion - gone!
    72 Tahiti 16' 468 Olds Berkeley jet - SOLD!
    11 RZR XP, 08 Polaris Scrambler, 06 Rhino, 06 Joyner 650 dune buggy, 04 KFX 700
    In a house, on a street, in a city, in Arizona.
    Quote Originally Posted by hkunz View Post
    Yeah, it is a Ford... they just figure that you'll blow it up before it ever needs to be changed and a new one can be slapped on at that time.
    Sep 2008
    Yuma, Az
    Quote Originally Posted by carveronline View Post
    add a remote system. auto filter would do just fine.
    ($50.00 bucks at summit)
    boatless....
    Senior Member milkmoney's Avatar
    vegas
    i have a 460 and use the stps8 filter, its a shorter one than regular, see pic. blue thingy..lower right..
    Senior Member bp298's Avatar
    LHC
    a good car filter is fine - wix, k&n...
    how long is that thing, and why are you running an evinude oil filter???
    Anaheim Hills
    Quote Originally Posted by jordy View Post
    Haha. I thinks thats actually described in the owners manual.
    Why not just cut the stringer? Im sure a sawzal will take care this issue.
    Im sure it will be ok, you have two of them.
    Glendale Arizona
    This is what I use. I had the remote with stainless lines and anodized fittings and got rid of all that crap for one of these. I much prefer this setup. Nice n neat, compact, still able to run a full size filter, clears the stringer and engine rail and works great. Nomenclature isn't 100% correct though. It says rotates it to the front. I've got mine going to the back. You can position it any which way.
    Great piece and as I recall pretty resonably priced. I think it ended up being less than the remote, the line and fittings to reach it.
    Yeah it's dirty.............so what.
    vegas
    hey dan, does running a shorter filter like i do, have any bearing on the oil flow???
    cj812 ralph brunt's Avatar
    long beach
    k&n hp2004 is the short filter and works fine.
    if you go to a re-location kit DO NOT use the cast one. i had one blow off the block (bad threads) could have been really bad.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Shorter filter or the offset deal but whatever you do its still a Ford
