Scoop question
Results 1 to 11 of 11
Scoop question
    Senior Member CHRISG82's Avatar
    New york
    Default Scoop question
    I have a bug catcher style scoop on my boat i have a problem keeping it straight,the pressure from the wing nut holding down the filter isnt enough to keep it from moving...the boat has a standard quadra jet 4bbl,any suggestions?? Thanks
    Apr 2009
    San Diego, CA
    Some people drill and tap a set screw in the top of the carb, bottom ring of the scoop. Doesn't take a very big screw at all.
    Q.C./Big River
    I just use a bolt, should be 5/16 or 3/8, and run it down the flame arrestor to the carb. Tighten it until the scoop doesn't turn anymore and give it a look see every so often. If you don't run a flame arrestor then it looks like a set screw is a good option. Hope that helps.
    Drill a very small hole (horizontally) in the air horn lip and cut a small cooresponding slot in the scoop base , it will hold it in place well Tom
    no need 2 fake it. 84Condor's Avatar
    Yuma, Arizona, United States
    Or do as I did, drill a hole in the scoop and run a piece of allthread down to the t-stat housing and cover it with steel braided hose and tell the idiots who ask that its water injection hahaha!
    "i'm into snatchin' kisses... and vice-versa!" haha
    small timer The Jerk's Avatar
    El Dorado, ca
    off topic -
    wheres a good cheap place online for a air cleaner and scoop setup?
    thanks
    Senior Member Beerguy's Avatar
    Lake Havasu AZ.
    Quote Originally Posted by The Jerk View Post
    off topic -
    thanks
    go to "parts spam" here on this site, and search "scoop"
    good luck!!
    Save the Salt
    Charlotte, NC.
    off topic -
    thanks
    Define cheap?
    Member blownt's Avatar
    Houston, Texas
    can also try a short piece of 5/16" or 3/8" SS or steel tubing. Slip it over the threaded carb stud. Make it just alittle shorter to the inside bottm of the filter lid. Then you can clamp down on the bolt without fear of flatting the filter element. Works better on dual carbs though.
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    I made a couple of these to put in my scoop.
    I will probably end up making some taller ones to fit some spark arrestors under.
    Member pushingvws's Avatar
    auburn, ca
    off topic -
    thanks
    www.summitracing.com
